Is a flux welder too hot to use on body panels?
Old Jul 29, 2011 | 02:27 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I'm gonna shave the door handles but the body shop wants $150 and thats with the doors off, handles/lock removed and the area sanded to bare metal, plus I'll finish the job with body filler, etc. I have a flux welder that I use for general stuff but I'm worried it will be too hot and warp the surrounding door metal (22 gauge I think).....any thoughts? input?
Old Jul 29, 2011 | 02:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is a flux welder too hot to use on body panels?
I think splatter and flux contamination would be a bigger concern.
Old Jul 29, 2011 | 03:04 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
I could get around the splatter issue but you do raise a good point with the contamination.....hmmmmm.....maybe JB weld!.....lol
Old Sep 4, 2011 | 09:03 AM
morb1lee's Avatar
one could spot weld across from eachother untill you went all the way around...like you would tighten bolts on a wheel...id let it cool after a few welds though to help prevent and distortion...my thoughts if thats the route you'd go...or just buy a tig welder.
Old Sep 4, 2011 | 01:23 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
n/m
Old Sep 5, 2011 | 04:00 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
A flux welder wont be too hot. You just need to weld, let it cool, weld, cool, weld cool. Just weld in spots spaced out or the metal will warp. Patience is the key. I would never consider using a flux core welder. Too much spatter and mess to grind away. Grinding away the extra metal can actually get hotter than welding and cause warpage.
Old Sep 5, 2011 | 05:38 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
"flux contamination" isn't a problem with good multi pass wire.
will say right on the spool, multi pass
Old Sep 11, 2011 | 03:28 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Can you upgrade your welder to use solid wire & gas? MIG is the best way to do a job like this. You can get a small C25 bottle or even straight CO2 & a small spool of wire for less than the body shop wants. Although you'll still need a regulator, etc on top of that
Old Sep 11, 2011 | 06:22 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
the flux would be a big issue. you would have to grind off all the flux before you could do the next set of welds.
if you do not want to upgrade you welder, you could just use body panel adhesive, it would be just as strong as welding with out the heat, time, or grinding of welding. ether way just remember to use seam-sealer on the inside.
Old Sep 13, 2011 | 01:35 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
HAHA!.......check out my thread "shaved my handles using 3M panel bond"......thanks buddy!
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
neekolzun
Aug 24, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
