Found problem with Hatch motor, how do I fix it?
Old Aug 17, 2011 | 03:45 PM
AggieIROC13's Avatar
I took apart my hatch motor and assembly to try and figure out why it wouldnt pull down my hatch when I close it, I couldnt find anything, so I put it back together in the down position so it would just stay down until I could fix it properly. When I hooked it all back up and grounded it, the motor pushed it back up, so I thought I accidentally fixed it. Then I closed the Hatch and the motor didnt do anything, so I am pretty sure there is a switch somewhere in there that I need to fix so that it knows when my hatch is closed, has anybody done this before or knows how I can fix it? Thanks.
Old Aug 17, 2011 | 06:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Found problem with Hatch motor, how do I fix it?
There's a small lever in the top that gets pushed when the hatch is closed - activates a relay in the rear under the plastic.
There's also a small circular button with a leg on it, that turns as the hatch is opening/closing - it has a spring that often breaks or flies off.
Maybe that helps.
Old Aug 19, 2011 | 07:34 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Lon from Top Down Solutions is top notch in this area. He's usually kicking around the boards here if you can't find the answers in your searches
stalkier
Aug 13, 2015 12:59 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
slade5612
Aug 11, 2015 07:19 PM
antares57
Aug 6, 2015 07:47 AM
