replacing door check link divets
Old Sep 17, 2011 | 07:02 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hey there
anyone know where i can buy new check link rivets for my doors (camaro)
check the picture what i mean:
Dennis
Old Sep 17, 2011 | 11:23 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: replacing door check link divets
Hawks wants $600 for all four complete hinges. I saw a guy in a thread on here who got greaseable ones (check links). I dont know where to get these (greaseable or not) but im in the market for them as well so hopefully someone chimes in. Hawks does sell the pin and bushings.
Old Sep 18, 2011 | 12:41 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
TDS, a sponser here.Sells the greaseable hinge pins.
Old Sep 18, 2011 | 03:46 AM
Car: camaro iroc-z
i don`t look for the hing pins.they are al great by me.
i need only the check link rivets!!
it`s comming loose by me ( look the picture)
Old Sep 18, 2011 | 10:26 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Sorry, no easy or inexpensive solution. Not availeble separately from GM. However, GM does sell a replacement door hinge assy but it is VERY expensive. A prior owner replaced the rivet on the drivers door hinge of my Firebird with a bolt and nut.
I suppose you could grind the bottom of the rivet from a junker that was in good shape, then weld a washer onto the base of the rivet. If you're careful the repair won't be visible from above.
Lon
Lon
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
