Can I reclear after wet sanding?
Old Sep 17, 2011 | 07:39 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I sprayed two coats of clear on the body last night and wet sanded today to 2000 grit. I have most of the orange peel out but I'd like to spray another wet coat of clear. Can I clean and reclear now or is 2000 to fine to spray over? Thanks
Old Sep 17, 2011 | 07:52 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Re: Can I reclear after wet sanding?
I don't see why not. Although it seems like it would cause the final coat of clear to have a hazy look to it.
I color sand all the time, then clear. But never resprayed clear after sanding. You usually buff the clearout after wet sanding...
Why do you want to spray more clear?
Old Sep 17, 2011 | 08:03 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
I read a couple forums and the guys claim it looks "amazing" when done. Guess I'm just PO'd with the orange peel on one side and figured shooting another coat would even things out...I only sprayed the body so far
Old Sep 17, 2011 | 08:35 PM
EvilCartman's Avatar
Car: '82 Z28
Why not just wetsand it smooth and buff it out? You can wetsand and then reclear no problem too though.
Here's a couple links to some pics with the orange peel I had to deal with. Before and after. No additional clear was put on, it was just sanded and buffed out.
Old Sep 17, 2011 | 08:51 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
You should have waited a few more days to wet sand, the clear was probably balling up on your paper. I can almost guarantee that you don't have all the peel out if all you did was sand with 2000. Wait a couple more days, wet sand with 600 then re-clear. Don't burn through.
Old Sep 17, 2011 | 08:54 PM
I just wetsanded from 1000 to 1500-2000-3000 then buffed it out... and got a mirror.
Attached Thumbnails Can I reclear after wet sanding?-img_0863.jpg   Can I reclear after wet sanding?-img_0861.jpg   Can I reclear after wet sanding?-img_0931.jpg
Old Sep 17, 2011 | 08:55 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
That looks awesome!......IDK...I guess I'm just **** and I have a whole gallon of clear with a shelf life of a year so whats one more coat gonna hurt if I can spare it......I'm only respraying the quarters/sail panel/roof anyway....but thanks!
Old Sep 17, 2011 | 08:59 PM
go for it!
Old Sep 17, 2011 | 09:00 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
I started with 500 on the really rough side and worked up to 1200.....most of its out.......the other side and window frame weren't that bad.....the can states you can sand/polish after 8 hours so thats what I went by
Old Sep 17, 2011 | 09:10 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
window frame and roof
Attached Thumbnails Can I reclear after wet sanding?-img_2234-1-.jpg   Can I reclear after wet sanding?-img_2238-1-.jpg   Can I reclear after wet sanding?-img_2241-1-.jpg
Old Sep 17, 2011 | 09:41 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Based on those pics there's still more sanding to do. Wait for it to harden up a bit more then hit it with wet 600 until there is a uniform dullness with no specs of shine. If you're careful you can over-reduce your clear by 10-15% and that'll help with orange peel. It'll be a bit less viscous, so be careful.
Old Sep 17, 2011 | 09:58 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Thats what I thought....thanks
Old Sep 17, 2011 | 11:08 PM
It should look like this...
Don't have a closer pic from when I wet sanded. But thats the final 3000 over. All one single dull shade. No pot holes or valleys in the clear so that shiny places (un sanded clear) are gone. To put it into simple terms.
Old Sep 18, 2011 | 01:19 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i may be a little crazy, but that shade of red looks pretty damn good flattened out like that....
Hotrodboba400
Dec 10, 2019 07:07 PM
92-Formula
Dec 12, 2015 10:34 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
