Help installing hood vents
Old Sep 20, 2011 | 12:30 AM
da84Berlinetta's Avatar
Car: Trans Am
Transmission: t5
Axle/Gears: 3:73 borg
86 trans am- has 4 vents on the hood top two small ones clip in but the front two square vents bolt on from the underside of the hood. The problem i ran into was finding a bolt to use under the hood to make the vents stay on. On the vent itself it has a two plastic pieces that a bolt must go around and screw on the outside i think? if youve done it before you should know what i mean any input helps
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bryan623
Aug 10, 2015 11:33 AM
