adhesive service kit. P/N 9636067...
Old Oct 8, 2011 | 12:57 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I need to put my rear hatch trim back on around the window whats the equivalent to the 9636067 kit and what do i really need from it... i found urethane adhesive but not sure if theres going to be a difference from one to the one that's in the GM kit?
Old Oct 8, 2011 | 05:57 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: adhesive service kit. P/N 9636067...
That's just a primer for the urethane. You can use the primer or just use a primerless urethane.
Old Oct 8, 2011 | 06:49 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you mean the black metal trim that goes all the way around the glass? i just removed mine to repaint it and put it back on it wasnt held on with any adhesive at all. needed a rubber malet to get it back on.
Old Oct 8, 2011 | 07:51 PM
FueledSoul's Avatar
so they make a primerless urethane then? so no need to prim before applying?
Old Oct 8, 2011 | 07:54 PM
FueledSoul's Avatar
Yea that's what im talking about. mine and a few others i have taken off had adhesive holding them to the glass i had to do the burn method get the trim to separate it self from the glass
Old Oct 8, 2011 | 07:57 PM
travis401's Avatar
Car: 91 Camaro RS
i dont think the adhesive is really needed. i had to give it some nice whacks with a rubber mallet to get it back on. its not comming back off without some prying.
Old Oct 8, 2011 | 08:37 PM
FueledSoul's Avatar
mines just the opposite it needs to be bonded in some places... i think i read some where that on some years they had adhesive and other years didn't but i can not recall where i saw that
Old Oct 8, 2011 | 10:42 PM
travis401's Avatar
Car: 91 Camaro RS
that sucks, i didnt read up before i pulled the rear hatch apart, i just winged it. kinda glad now that it didnt have any adhesives.
Old Oct 9, 2011 | 07:33 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I think they all had adhesive from the factory. The service manual I have is 1985. I don't think they even had primerless urethane then. Some applications of urethane on structual glass and such may still require primer but for trim around the hatch glass I can't see where it would be required or needed.
Old Oct 9, 2011 | 10:00 AM
FueledSoul's Avatar
Good point... i think its more to do with having a prepped surface for it adhere and bond to tho just like paint
Old Oct 9, 2011 | 10:10 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
That's pretty much how I take it. But I wouldn't want to sand on my glass. Putting urethane on the edge of the glass, where it's not as smooth, would be my choice. Service manual may say something different. Scuffing of paint inside trim may help adhesion also. I also agree, most of them were pretty tight without adhesive. Urethane on edge of glass would also act as cushion IMO. Good luck, be careful.
88SS6SPEED
Nov 11, 2015 07:05 AM
bigjay89gta
Oct 15, 2015 08:04 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
racereese
Oct 3, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
