is this gonna be hard to fix?
Old Oct 18, 2011 | 07:25 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
back into a pole tonight, how hard is this gonna be to fix? thinking about popping that dent out so it will be cheaper when i get it repainted.
Attached Thumbnails is this gonna be hard to fix?-img_2424-1-.jpg   is this gonna be hard to fix?-img_3560-1-.jpg
Old Oct 18, 2011 | 07:36 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Re: is this gonna be hard to fix?
Don't pop the dent, you will create high areas, let the shop hammer and dolly it out the right way, you do not have a lot of labor there. The paint looks good so they should be able to match that with some blending. I know you think it will just pop out but trust me you may create more work doing that.
Old Oct 18, 2011 | 07:45 PM
Engine: L31 350
alright ill let the shop do it and the paint isnt even a year old, i got it repainted at the end of febuary, like the 28th.
Old Oct 20, 2011 | 10:41 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
You might be in the new quarter/patch panel nieghborhood. With several creases on bodylines I dont see it ever going back into original shape.
Old Oct 21, 2011 | 11:00 PM
puma1552's Avatar
New quarterpanel, if I had to wager a guess.
Old Oct 21, 2011 | 11:17 PM
ronnoco67's Avatar
Car: 91 RS vert
I agree and also have a 91 droptop! As a former bodyman I would say leave it alone and let them fix it. That panel looks solid and you'll just stretch it trying to "pop" it out. Shouldn't cost a ton.
Old Oct 21, 2011 | 11:20 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
my son used this on his car.
did a real nice job, because you go just a little at a time
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
great opportunity to learn how to do it yourself. pull your hatch plastic and hideaway cardboard, and see how much of it you can get to from behind. I think you're going to find this will be a great learning experience
Old Oct 22, 2011 | 06:43 AM
Engine: L31 350
Mark, iv already looked at it from inside behind that plastic, it's just one solid dent it's like a big bubble really
Old Oct 22, 2011 | 09:06 AM
58mark's Avatar
it might not be the way a big body shop would do it, buy this is what I would do. get yourself a body working kit including a dolly, and start tapping the dent back into place. Get it close, maybe down to an 18th of an inch of original. Sand it down, put some epoxy primer over the bare metal (SPI epxoy works great under body filler) and then use some good quality filler like Rage or Z-grip. Sand it down smooth and flat with a flexible long board, it might take a little practice but that's ok. When you are done, spray more epoxy over the top to fill in pinholes and keep moisture out.
Don't forget to mask off and cover anything you don't want paint on. This whole post becomes much trickier of you don't have access to a air compressor, and at least a cheap gun. Even a $15 harbor freight gun is fine for something like this
Old Oct 22, 2011 | 12:29 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
get a portapower push it out slightly using a block of wood so u get a more even push then hammer it with a dolly
Old Oct 22, 2011 | 12:37 PM
ronnoco67's Avatar
Car: 91 RS vert
I'd agree with this route if you're not experienced with a hammer & dolly. The main thing is, if you're going to do it yourself, go slow and be patient.
Old Oct 22, 2011 | 01:14 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
that dent isnt going to "pop" at all, its creased which means you pretty much screwed it up big time. so to a shop and get an estimate then paint it yourself or whatever to keep costs down.
Old Oct 22, 2011 | 01:53 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Any of you guys suggesting dollys and hammers and whatnot... can you guys give me an idea of what would be needed? I've got some ripples from someone I think dropping the spare tire jack down into the spare tire well and getting stuck and having to pull it back out to put it back in right. Just some mild ripples with scratches on the inside of the car. But when I do the repaint it's got to be straightened out, and since some of it is raised Ido nt want to just bondo it straight. I'd rather get it back in line with where it should be first beforeI go to body fillers.
So I was looking up dollys and I found a whole mess of em in a million different shapes. Which should I be looking for for general purpose stuff? Can I make one out of a block of wood?
Old Oct 22, 2011 | 07:58 PM
91 Droptop's Avatar
So I was looking up dollys and I found a whole mess of em in a million different shapes. Which should I be looking for for general purpose stuff? Can I make one out of a block of wood?[/quote]
To be honest, this is not a job for you to try yourself; take it to a shop. You may make it worse, and DO NOT USE A PORTA-POWER
Old Oct 23, 2011 | 12:34 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
You can not make a good dolly out of wood. One of my favorite dolly's is the "universal" dolly. It has a lot of different surfaces for a lot of different shapes. Another is the "comma" dolly. The wedge end gets into some tight spots.
Old Oct 23, 2011 | 12:40 AM
Car: 86 T/A
Engine: 5.0 TPI
What makes a dent like that easy is the amount of access you have, to that area, when the inside trim is removed.
What others have said is right. You could make it worse by doing it yourself. I look at it and think ... piece of cake!
Old Oct 23, 2011 | 07:30 AM
Hipster's Avatar
Yeah, if your not experienced you can really stretch the metal and make more work, it's not that bad, an afternoon's work for the body work side.
The paint looks like single stage on your car, 1 y/o. Most repairs are done bc/cc and blending. I'd go back to the shop that did it, same brand of paint, same formula, better match, etc. Blends on sail panels sometimes show up later so it would be your call if you wanted to carry paint work across the roof and right 1/4.
Old Oct 23, 2011 | 09:53 AM
58mark's Avatar
If you do decide to go at it yourself, you actually can get epoxy primer in a can. For this I would recommend sanding as much of the old paint off as possible with a wire brush on a wheel, put the filler on (after you get the panel close) and then spray the epoxy on to seal it. Try to stay away from normal rattle can primers that you buy at autozone or wal mart, the shop that repaints the car for you might not do the job if they are putting urethane paint over rattle can.
Old Oct 23, 2011 | 10:42 AM
Engine: L31 350
I'm taking my car back to maaco saterday to see what it's gonna cost to get it repainted and maybe have them pop the dent. But I'm gonna have. Body man here look at it for me and see what he would charge to pop it
Old Oct 23, 2011 | 10:45 AM
58mark's Avatar
don't minimize what needs to be done to fix it by calling "pop the dent" If I was a professional body man, that would **** me off.
you've got to work the metal, shrink it, reshape the best you can. It's not a pop, that metal is creased, warped and stretched out of shape
Old Oct 23, 2011 | 11:14 AM
Car: 1992 Camaro RS
Well to slightly hijack, this is what Im looking at on MY car:
Im not experienced in body work at all but I figured something that mild I could get it close enough for body filler... Is it really something that I'll end up mangling more than helping? Should I just have a body shop work that particular part?
I've got a LOT of little dents herea nd there on the car and Im wanting to repaint it myself. Lots of little door dings and things like that, that I'd like to take care of myself instead of spending a fortune on a body shop to do it... Now Im reconsidering.
Old Oct 23, 2011 | 11:29 AM
58mark's Avatar
that's not that bad. put a metal straight edge on it to see if it rocks on any high spots. you can also get a better idea of how deep the dents are then.
the only tricky thing about that is it's on a body line, which means when you sand the filler you have to be careful you don't lose the horizontal crease
body work can be very rewarding and frustrating. There are a few spots on my car I thought I had perfect, but they still show a small dent after I polished them out. I think my filler shrank over time.
Old Oct 23, 2011 | 12:24 PM
Car: 1992 Camaro RS
Unfortunately I KNOW it's all high spots, becuase they were dented from the inside. That's why I figure I need to get a dolly and try to line it back up and then throw filler on it.
What filler do you use? Ive used bondo before, but I heard some people say it's awful.
Old Oct 23, 2011 | 12:26 PM
58mark's Avatar
I like z-grip, but next time I'll probably use rage because of the shrinking I experienced. Maybe rage will be better
Old Oct 24, 2011 | 09:15 PM
Engine: L31 350
took her to a shop today and to have it rapaired and repainted it was going to cost just under $1000. well i got it home and beat on it alittle and got most of it out and took my touch up paint and sprayed it so it looks alot better and matchs again so that will hold me off for awhile. ill get pictures tomorrow.
Old Oct 24, 2011 | 09:27 PM
58mark's Avatar
I'm glad you did some good, but if you're that close, the filler has got to sound very tempting
Old Oct 24, 2011 | 09:28 PM
Engine: L31 350
it kinda does to be honest lol. ill post pictures tomorrow to get more opinions on how it looks as if i need more work or filler.
Old Oct 24, 2011 | 09:49 PM
Car: 91 z28
Transmission: 4L60e
http://www.eastwood.com/15in-adjusta...ile-gauge.html
buy one of these, I bet you are not as close as you think.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
