crosse fire hood's ?
Old Nov 12, 2011 | 11:31 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok i have the fiberglass corssfire hood the flaps do not work i know of a steel crossfire hood same thing whach one is lightr i want to say the fiber glass one.And whach one is made batter and has cleaner lines and will last longer? and if you had to pix fiberglass crossfire hood vs steel crossfire hood what one would you pix.?
Old Nov 12, 2011 | 12:13 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: crosse fire hood's ?
The fiberglass one is probably lighter. They'll probably last about the same amount of time and the steel one probably has better lines.
Old Nov 12, 2011 | 12:32 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the fiberglass one is indeed lighter. and if you do change to the steel hood, youll need to change your hood shocks as well. the fiberglass hoods use a weaker shock than the steel hoods.
Old Nov 12, 2011 | 02:15 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Fiberglass is lighter, steel probably has cleaner lines, longevity depends on treatment, if maintained either will last forever, if not, well the steel hood can rust out, the glass one cannot, but it can however be damaged/broken easier.
Old Nov 12, 2011 | 02:32 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
All Crossfire Camaros had the fiberglass hoods with functional hood flaps. They never had steel hoods, which were about 20 lbs heavier.
Old Nov 12, 2011 | 04:27 PM
Drew's Avatar
Also keep in mind the CFI glass hoods had some "issues" in the early years. There is a TSB about the hoods coming apart at speed, smashing the windshield, etc. Something to think about when considering longevity.
Old Nov 12, 2011 | 05:17 PM
Engine: 3.8, 3.4
2 words: hood pins, even if it delaminated it wouldn't go anywhere, and really, fiberglass is not at all hard to repair, and requires no special tools, unlike steel.
Old Nov 13, 2011 | 05:49 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
i have the fg cf hood .CFI glass hoods had some "issues" in the early years. There is a TSB about the hoods coming apart at speed, smashing the windshield, etc that is the only thing that worrys me about it but it is a 84 hood .chazman you are rong you can read all the tech you want but im comeing to know that its not all right i have seen cars that should not have a part thats there cuse of the oems and i have seen parts that shood be there and it is not there seems to be miss info on the 3gens some times cuse gm did notalway do as thay sed that did. and do any one know of cheap hood struts ?
KCG
Jun 24, 2020 04:33 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
