88 gta taillights
Old Nov 15, 2011 | 01:47 PM
Drewmeyes88's Avatar
Car: 88 firebird ws6
Engine: 350 tpi
Transmission: 350 turbo
88 gta taillights
Ok so I have a 88 firebird formula and i found a pair of 88 gta taillights for 80 dollars in good condition. How hard is it to do the wiring? Should I even get the taillights? I think they look better and one of my taillights is cracked.
Old Nov 15, 2011 | 02:32 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: 88 gta taillights
The best thing to do is get the harness with the lights. It's an easy job if you can get a matching harness. If the seller doesn't have it we can probably help you with one. It's a lot easier to splice in a Trans Am tail light harness than it is to make your existing harness work.
Old Nov 15, 2011 | 10:39 PM
Engine: 350 tpi
How much is the wiring?
Old Nov 15, 2011 | 11:43 PM
Former Sponsor
Car: Too many
We have Trans Am tail light harnesses for $12.50 plus shipping.
Old Nov 16, 2011 | 12:27 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
T/A taillights are a big upgrade over the base lights IMO...you can probably find them cheaper though, I ended up getting just $25 for a set I had a few years ago.
Old Nov 16, 2011 | 07:46 PM
MNformula350's Avatar
I wouldn't say that
I used my factory Formula harness, Changed the turn signal socket to a flat 3 wire socket, and wired the turn signal bulb to come on with the tail lights, as well as flash when signalling.
All in All it took maybe 15-20 mins.
Old Nov 16, 2011 | 08:14 PM
Former Sponsor
Car: Too many
Originally Posted by MNformula350
I wouldn't say that
Neither way is really hard but considering Formula lights use six sockets per light and two different styles and Trans Am lights use four sockets that are all the same it only makes sense it would be easiest to start with the correct harness.
Old Nov 16, 2011 | 10:48 PM
racerx520's Avatar
when and if you change over to the GTA tail lights, you can get the sequential turn signals too, i put them on my 87 and i love them. theyre neat and just one of those little things that sets a car apart from others...IMO
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
bjpotter
Oct 4, 2015 07:48 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
Navy8125
Oct 1, 2015 11:24 AM
