nose and rear bumper
Old Nov 21, 2011 | 04:32 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
So I've always hated the black bumpers on the front and rear of my Formula. I would like to have smooth front and rear like a TA. I was wondering if l used a 85-90 TA nose without the ground effects would it work? Would that TA nose have the same shape as my nose minus the bumpers and front end ground effect... Not sure how hacked up the TA nose would be after removing the ground effect. As for the back end cover I was thinking of using a 91-92 Formula bumper or 85-90 TA rear bumper minus the ground effect, what do you guys think and has anyone done this?
Old Nov 21, 2011 | 07:15 PM
Car: 89 Formula 350
Re: nose and rear bumper
Ok, so I'm hearing the ground effects don't come off the 85-90 TA nose. So now I'm looking into a 91-92 Formula nose. From what I've found in a search I see is need the nose and support as well as replacing my head lights with 91-92s... I have two questions???
1. Will my 89 hood work with 91-92 nose???
2. Will my 89. Fenders work with 91-92 nose????
Old Nov 21, 2011 | 11:07 PM
Car: 89 Formula 350
TTT
Old Nov 21, 2011 | 11:32 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
yes to fender, hood with bumper.. headlight yes.. not positive on the connector
Old Nov 22, 2011 | 02:47 AM
waterboy87's Avatar
In addition to the bumper cover, you also need the actual metal bumper, impact absorber, parking lights/ turn signals, and grills as all that is 91/92 specific.
Old Nov 22, 2011 | 08:51 AM
Car: 89 Formula 350
[QUOTE=88gta3508;5100984]yes to fender, hood with bumper.. headlight yes.. not positive on the connector[/QUOTE
I read that the head light trim from my 89 won't work with the 91-92 nose?
Old Nov 22, 2011 | 09:19 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Honestly the easiest way to make the inserts disappear is to grab another set and paint them body color.
It was easy 4 me. my car is painted black.
the 91 formy rear bumper will fit with the correct plastic absorber. not sure if they changed the metal support.
the 92 front bumper will bolt right on with the correct metal support(?) and plastic impact absorber but the park light harness needs modded unless you get a complete front light harness.
The 91-2 also uses smaller headlights, diff buckets, lids and plastic bezels.
If you leave your 89 lights on they may or maynot work with the 91 bumper. I don't know.
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I have a bone stock '91 Formula sitting in the garage, I'm actually taking it down to Queens this weekend (crossbay blvd area) if you need to compare anything with yours...
Old Nov 22, 2011 | 09:40 AM
Car: 89 Formula 350
Thanks guys, I'm just starting to get parts together. Just made my mind up to do this yesterday. Still need to find all the parts.
Old Nov 22, 2011 | 09:50 AM
TTOP350's Avatar
I have a 91-2 car that needs a super nice bumper cover also. Ive been looking for a long time and either they wont return my ?s or the cover is just screwed up sumthn bad.. you may have to buy a complete car and part it out..
Old Nov 22, 2011 | 08:03 PM
Car: 89 Formula 350
So I might have found a 91-92 Formula nose/front bumper cover. I am now wondering about the head lights. I'm not sure if my current 89 head lights will work with the 91-92 nose? I see the trim around the lamp of the head light assembly looks different..So do I need new head light assemblies or just the trims around the lamps or will my current setup work as is with the 91-92 nose???? Thanks
edit.... Just ran some masking tape along where the new body line would be using the 91-92 hood. I then opened the head light manually, the trim at on the head lamp would hit the hood and need to be cut back, also the bottom 3/4" of the lamp itself would be below the top of the new nose line... not a real big deal but I'm still debating the head light issue.. Might be possible to use my head light assembly and just change the trim and lamp out to the 91-92.
Old Nov 22, 2011 | 08:50 PM
TTOP350's Avatar
just swap out from the headlight hing up and you'll have what you need.
And wow on the bumper cover. nice work!
Old Nov 23, 2011 | 08:00 PM
Car: 89 Formula 350
parts needed for 91-92 nose conversion.
1. Bumper Cover
2. Crash bar
3. Absorber
4. wiring harness
5. head lights
anything I'm missing??
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
