Got Pictures of Ground Effects Behind Front Wheel?
Old Dec 11, 2011 | 07:13 PM
reefland's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L
I need to figure out how this piece is attached to the car. Previous owner tried pop-rivots which needs to be fixed. I have removed the Z28 emblem and just don't see how this piece is supposed to attach to the car. Any pictures or knowledge would be helpful.
Old Dec 11, 2011 | 07:26 PM
Twin_Turbo's Avatar
Re: Got Pictures of Ground Effects Behind Front Wheel?
2 screws behind the emblem, self tapping ones that go straight into the fender, often rusted out and loose.
Old Dec 11, 2011 | 07:34 PM
reefland's Avatar
Engine: 5.7L
Thanks. There weren't any holes behind the Z28 emblem when I removed it but I'll certainly screw two through there and cover with new emblem.
Thanks!
Old Dec 11, 2011 | 08:13 PM
cdoyle's Avatar
Thanks!
no there is a bracket that connects to the GFX, that has studs that go into the fender and is bolted on from the other side of the fender.
Don't screw into your GFX into the fender!
Just remove a couple of those plastic clips that hold that inner plastic splash shield inside the wheel well. Then look in, and you'll see them.
If the bracket is missing, just go get one at a wrecking yard and fix it right
Old Dec 11, 2011 | 08:14 PM
Twin_Turbo's Avatar
What bracket? There wasn't any brackets on my irocs. Maybe we're not talking about the same location?
Old Dec 11, 2011 | 08:19 PM
reefland's Avatar
Engine: 5.7L
I'm talking about this one right behind the wheel. There aren't any holes where the emblem was (as you can see) but there also isn't any bracket on the back side of the piece with studs going through the fender. That might be the problem; the bracket referred to above is missing. Although I'm interested in fixing it right, it seems that a couple of self tappers would do the trick just fine and be completely hidden by the emblem. As long as I can get the screws to sit flat?
Attached Thumbnails Got Pictures of Ground Effects Behind Front Wheel?-driver_fender_primered.jpg
Old Dec 11, 2011 | 08:44 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
You should have holes in the ground effects like in the pic below.
Old Dec 11, 2011 | 09:07 PM
cdoyle's Avatar
They must have changed it for the 91/92 style, mine have a bracket on the backside of the GFX. It has threaded studs that go through holes in fender, then secured from the inside of the fender.
Old Dec 11, 2011 | 10:30 PM
scottmoyer's Avatar
I just looked on eBay for 91/92 ground effects and I see a lot of pics of them with the emblem still intact. The 91/92 set must install differently than the previous years. Disregard my picture above then as it must not pertain to your situation.
Old Dec 12, 2011 | 05:39 AM
Twin_Turbo's Avatar
91/92 is different with a bracket indeed and studs w/ nuts. My brother confirmed that. Much better design! The prev design is the suck.
Old Dec 12, 2011 | 07:32 AM
reefland's Avatar
Engine: 5.7L
Thanks guys. The only thing that sucks is that self tappers would have been much easier...
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Oct 3, 2015 05:34 PM
kah992
Aug 19, 2015 02:55 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
wruiz
Aug 11, 2015 02:59 PM
