Upper door pins
Old Dec 23, 2011 | 09:17 PM
Apolo's Avatar
Car: Camaro 1987
Engine: V6 2.8l MPFI
Upper door pins
Hi i saw on ANDYZ28 site, that the kit greasable for sagging doors also works on 4th gen, so on ebay there are one kit for 4th gens, 4 pins for only 74.95, the question is do you guys think the kit works on my 3rd gen?
http://www.ebay.com/itm/GM-CAMARO-FI...ht_4805wt_1037
Old Jan 12, 2012 | 08:47 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: Upper door pins
You know I have the same question. My passenger side door is low on the back end and everything I've read here says there is no adjustment, the pins have to be replaced. Well, I've looked at several sites that offer door hinge replacement kits in form or another and I can't figure what I need either. I've never replaced a door hinge before so what wears out exactly or how do you determine what is needing replacing?
Old Jan 12, 2012 | 09:25 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Upper door pins
That will work for only the upper hinges of two 3rdgen doors you still need the lower pins and bushings...
If your going to go thru all the work you might as well install new lower detent pin and rollers too
Old Jan 12, 2012 | 09:31 PM
FueledSoul's Avatar
Re: Upper door pins
There is no adjustment for saggy doors... once you replaced the worn parts and the doors ant lining up or shutting right then there are ways to adjust the doors but sagging doors are usually a sign that something in the hinges need to be replaced...
for an example for each door you'll need:
http://www.top-downsolutions.com/doo...able-p-38.html
http://www.top-downsolutions.com/low...ler-p-148.html
And you might as well buy new door strikers....
and a door spring Tool makes life easy
Old Jan 13, 2012 | 09:59 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: Upper door pins
https://www.thirdgen.org/forums/body...pair-pics.html
If you do it my way it will cost you about $20 total... and they are easily repairable if they start to sag later!
Old Jan 14, 2012 | 03:50 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: Upper door pins
I ain't doin' that.
Old Jan 14, 2012 | 09:57 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Re: Upper door pins
Everything I have read says that is the same as third Gen. I just got the ones in today for my door - I did not see that one until now or I would have bought it
Old Jan 15, 2012 | 12:39 AM
Apolo's Avatar
Car: Camaro 1987
Re: Upper door pins
Well, i got the kit, i bought just 1 kit, i dont know the cost of the labor of duplicate the Pieces in the usa, here in mexico is much more cheaper fabricate a couple of pin with bushings, actually if there are people interesed i could sell the kits but much more cheaper, like 30 dls
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
