How To "Bondo" or Something
Old Jan 3, 2012 | 11:06 PM
jahblah's Avatar
Car: 87' Firebird Formula
Heyy heyy yall (just watched family guy lol) i have been actively progressing in my mission to make my firebird look better but hit a speed bump ULTRA OMEGA HARD and now im in trouble..more or less anyway. Ok, i had fully sanded my car all the way down and decided to complete my hood scoop idea i started a thread about a little while back. So i measured, traced, and taped where they were to go. I did all that right but when i cut..i went too far in a couple spots so i have cuts outside of the scoop area. So now ive got to learn how to "patch" or bondo if you will. YouTube has videos but NO ONE has a dumbed down version. Anyway, could someone break it down in simplest form what i need and what i have to do? Please and thank you.
Old Jan 4, 2012 | 02:26 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: How To "Bondo" or Something
Please don't fill in the holes with bondo, especially if there won't be metal backing it. That's a ghetto solution.
Old Jan 4, 2012 | 04:00 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
weld the cuts closed, grind flat SKIM coat body filler, just to even out the dips. sand even and smooth, prime, paint
Old Jan 4, 2012 | 09:24 PM
Engine: LB9, LS1
This would be a way to do it. There's more to it than just bondo.
Old Jan 6, 2012 | 11:26 PM
jahblah's Avatar
Well i didnt bondo but i was in fact short on change soooo i used JB WELD!!!!! I know this route is unfavorable to many but it worked. Its solid as a rock...of liquid metal lol It not only bonds metals, but other stuff too including fiberglass...as in the fiberglass scoops i were installing. I molded a line of jb weld all the way around each scoops. Killed 2 birds with 1 grapefruit i also installed rivets around the scoops. Tomorrow im going to finish sanding the extra jb weld off. Thanks guys
Old Jan 7, 2012 | 12:10 AM
Engine: LB9, LS1
JB weld? Seriously? For body work?
The Presidential solution right here folks.
Old Jan 7, 2012 | 12:47 AM
jahblah's Avatar
Lol like i said, the is unfavorable by most. The weld and grind idea was top notch but i do not own a welder. Had to work with what i have. I know this wouldnt have even been remotely your idea but it worked for me.
Old Jan 7, 2012 | 07:29 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
if you plan on making any major modifications to metal peices (like a hood), you need to invest in a welder.
Old Jan 7, 2012 | 09:23 PM
jahblah's Avatar
Plan on it. Ive discovered how fun it truly is to perform successful modifications so i see WAYY more in the future (non JB Weld mods that is lol)
Old Jan 7, 2012 | 09:26 PM
travis401's Avatar
Car: 91 Camaro RS
HF had a decent fluxcore/mig dual purpose welder on sale over the holidays for 299.99. its the same one i picked up new off CL for $150. ive got it set up for fluxcore until i can pick up a small gas bottle.
Old Jan 7, 2012 | 10:28 PM
jahblah's Avatar
Yea man!!! Craigslist is AWESOME. I find ALL my stuff from there. But all the good priced welders go at the snap of a finger. Im waiting for another Miller or Lincoln to come by for cheap that isn't too far off my radar.
Old Jan 14, 2012 | 05:00 PM
travis401's Avatar
Car: 91 Camaro RS
http://www.harborfreight.com/welding...der-94164.html thats the welder i got, its on sale again till tomorrow
