camaro bumper on my firebird
Car: 87 Firebird and 93 Accord
Engine: Bird has a 355 ready to be put in
Transmission: TH-350
Axle/Gears: stock 3.43
I have and base 87 firebird that came with the 2.8(i think they tried to call it an engine). The front bumper has a crack running from almost bottom to top in the middle. I was wondering if i could simply bolt on the camaro bumper and keep the flip up head lights. I know that i would have to add some gfx to the car though to make it look right.
I know that there r those of u out there that dont like this, but I DONT CARE! I LIKE THE IDEA.
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
Re: camaro bumper on my firebird
The fenders are different, it wouldn't just bolt on. It would look weird as hell with pop up lights and holes for headlights also
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
It won't bolt up. If you manage to Frankenstein it on with a box of screws and a carton of duct tape you're still going to have two huge holes where the Camaro headlights were.
Bottom line is it won't fit and it'll look like crap. A 2x4 wired on would look better and have a better chance of lining up. If you want to make another cheesy Fire-maro then you're going to have to swap the fenders, hood, headlight support, bumper support, etc.. along with the bumper. Don't forget the wiring harness for the lights too.
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
thats a photoshop yevgenievich did for me last year when i had the same idea. the thread for this is here. firebird fenders are longer and slope down lower in the front than camaro's do, so the sides of the bumper need to be shortened. and the top needs to be lowered. i plan to do something like this to my car still but i now plan to use the top part of a 78ta bumper the grills and headlights. cuz my car is getting a retro theme with a 78 dash and spoiler, 68 tail lights and more.. i am in the part collecting phase of my project. and as soon as i got another vehicle to drive my bird will be completly gutted and completly redesigned from the ground up
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Whew! Thank god that's photoshop! I was about to get mad that someone f'd up a nice TA.
Transmission: t56
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
it actually doenst look half bad in my opinion
Car: 87 GTA
Engine: 5.7 TPI
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
If yours ever does come to fruition, and actually looks like it was done right, I will be surprised.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The Camaro nose will be too tall, because the Firebird hood drops approx. 4" lower where the hood & fascia line up. You would have to either section the Camaro nose or trim the top or trim the bottom for it to fit.
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
x3
But be tasteful please...
I think the nose and tail of the 91 firebird needs to be shortened about 3" in the rear behind the tires and 4" in the front in front of the tires. I have at least been thinking about the way to do it. Rear would be easy, front not so easy but doable.
Thanks for the info. i took a look at that link and people r saying that ill have to use the top half of the bird bumper and the bottom half of the cam bumper and fuse them together somehow
Transmission: t56
also the sides of the camaro bumper are bout 5 inches longer and would need to be shortened as well easiest way i could see this being in done is make a fiberglass mold of both bumpers and cut and fiberglass the molds together to build your new bumper..
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
