Restoring My 85 Iroc
Old Feb 16, 2012 | 12:37 AM
85Irocket's Avatar
Car: 85 Iroc
Engine: Don't have one yet.
Transmission: T-5 non wc
Axle/Gears: Disc brake 10 bolt with 373 gears
I just picked up a an 85 Iroc for $900 and have started to restore it. The car is rust free except for the battery tray and the spare tire well. Does anyone know if there is a patch panel for the spare tire well or what is the best way to fix it. Thanks.
http://i1249.photobucket.com/albums/...t/100_0250.jpg
Old Feb 16, 2012 | 12:41 AM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
Re: Restoring My 85 Iroc
my 91 was rotted in the same place in that pik....i cut the outer quarter and replaced it with one from a car in he junk yard....the inside i cut out the rust spots and filled it with fiberglass
Old Feb 16, 2012 | 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check out the POR-15 kit (paint, mesh, putty). Recommended.
JamesC
Old Feb 16, 2012 | 09:35 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Cut it out, clean it up, and weld in a new piece.
Old Feb 16, 2012 | 09:57 AM
85Irocket's Avatar
Car: 85 Iroc
I'll definatly be welding in new metal. Here is a pic of the car before it was stripped.http://i1249.photobucket.com/albums/...t/100_0244.jpg
Old Feb 16, 2012 | 04:57 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Those blue ones are nice! Good luck with the resto. You just have to stay motivated! I did an 89 and just finished it last fall. You can check out my thread if you want in the body section.
Old Feb 16, 2012 | 11:49 PM
85Irocket's Avatar
Car: 85 Iroc
Thanks I'll check it out. It won't be blue for long. I've always wanted an orange Iroc.
Old Feb 16, 2012 | 11:54 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
if you look at my album you can see my wheel well repair far worse condition then yours cut out metal and welded in new metal mien was on the drivers side but same deal.
Old Feb 17, 2012 | 04:00 PM
User Error 87's Avatar
Car: 1987 Trans AM GTA
Engine: 5.7 TPI
Axle/Gears: 3.73 POSI
POR15 is the best stuff out there
Old Feb 17, 2012 | 04:33 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Eastwood's Rust Encapsulator and Rust Bullet are good as well. When the weather breaks I'm gonna get a couple of these.
Old Feb 17, 2012 | 11:38 PM
85Irocket's Avatar
Car: 85 Iroc
Thats cool. I'm gonna get some of that frame coating. I'm also going to por15 the floors on both sides after i weld in some subframe connectors.
Old Feb 17, 2012 | 11:49 PM
85Irocket's Avatar
Car: 85 Iroc
Here is the latest picName:  001.jpg
Old Feb 20, 2012 | 12:12 PM
Engine: All 5.7's
Orange is good too, I've always wanted a blue one.
Old Feb 20, 2012 | 12:21 PM
85Irocket's Avatar
Car: 85 Iroc
I got the dash out and the rest of the body stripped and the windshield out. Time to start sanding.
Old Mar 12, 2012 | 09:43 AM
85Irocket's Avatar
Car: 85 Iroc
I haven't had a lot of time to work on the camaro lately. My whole family is sick. Gotta love that. I did get the pass door sanded to bare metal and primed. I'm going to shave the door handels and locks. I just gotta pick up some sheet metal.
Old Sep 2, 2012 | 06:42 PM
85Irocket's Avatar
Car: 85 Iroc
The camaro is completely stripped and on the rotisserie. It's slow going. I've started welding in patch panels on the floors. It's my first attempt at sheetmetal welding. I definatly need to get rid of the flux core wire and get my welder switched over to MIG.
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
g.l.mos
Aug 22, 2015 12:02 AM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 11, 2015 03:17 PM
