Headlight metal work
Old Feb 20, 2012 | 02:12 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Hi,
Is it possible to get the sheet metal piece behind the headlight in a Firebird and also the bottom piece that the L bracket screws into. I tought about getting the complete core support section that has the radiator section and the two headlight pieces each side but shipping from the US to Ireland is killing me.
Was wondering if I could get the passenger side metalwork I should be okay as the radiator support is fine. That piece isn't heavy so shipping shouldn't be crazy.
Old Feb 21, 2012 | 01:29 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Headlight metal work
That area behind the mounting plate definitely needs some replacement, but since it isn't an area you can see, you should be able to weld in some sheet metal and stock once you remove all the rot. However, if the whole headlight/radiator area is that bad, you prob should weld a whole front clip on. It will be tough to get someone to cut one off and ship it to you though.
Old Feb 21, 2012 | 04:10 PM
gholian's Avatar
Engine: 2.8 V6
The radiator section is okay rust wise. I can get the driver side piece off a car that has been wrote off in an accident. The passenger side is all I need. Tought someone might be making this section as it is an area that rots in them all. All I can find for thirdgens is a Battery tray and lower door skins. Is there anyone making any other parts?
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
