What to do when a moron ...........
Old Feb 28, 2012 | 01:11 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Jacks up the car in the wrong spot and bows out the fender. The POS PO i bought my car from jacked up the car where the rear of the front fender bolts up to the body. any one have any ideas on how to straighten this? i would assume it has been dealt with before. this guy just didn't care.
Old Feb 28, 2012 | 01:26 PM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Re: What to do when a moron ...........
You can "un-fold" that seam where most unknowns jack from, loosen the bolts and have someone gently push in on the fender crease just behind the front wheel till the fender lines up with the door then tighten the bolts, don't get too carried away pushing, you might dent the crease in the fender. You might need to pull the seam down some and that might pull the fender into alignment also.
Old Feb 29, 2012 | 09:31 PM
Willsmith305's Avatar
Car: 1989 Camaro RS
Engine: 305 Carb
Transmission: 700R4 Mild shift kit.
The guy i bought mine from did the same thing to both sides! Since I'm redoing the whole body on mine its not that big of a deal but I had to use a crowbar because the bolts were literally folded into each other. But what Realmac4 said is what you should do, straighten out the bottom of the fender behind the wheel wells if you can ( Curve it back into form )
Old Mar 1, 2012 | 07:11 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I have had to do this also...
Old Mar 1, 2012 | 07:21 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Mine too. Crushed flat against the underside. Caused the front of the ground effects to curve in a bit too...will be dealt with before paint I guess.
Old Mar 2, 2012 | 06:21 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
the metal where the fender joins the body looks like crumpled paper.
no respect for the third gen. hopefully im able to straighten it out. i appreciate the advice.
Old Mar 8, 2012 | 12:26 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Thats how mine is too along with the crumpled paper look. I pretty much got mine pulled straight down and then when I realized it wasnt fixing the fender I decided to take a closer look. Turns out both fenders on each side of my car have essentially been folded up (I can take pictures if you guys wanna see). So I am thinking when it comes time to paint I will get some new ones to throw on there, but until then I am not going to worry about it.
Old Mar 8, 2012 | 10:50 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I used a wide pair of panel vice grips and mine pulled back in fine.
Old Mar 8, 2012 | 02:04 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Is that pinch weld where the fenders/gfxs bolt up supposed to be vertical the length of the car? Does anyone have photos of a pristine stock original?
Old Mar 8, 2012 | 02:49 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I just got a hammer and a long blunt object and hammered it back into shape. It was a slight bend on mine though.
Old Mar 8, 2012 | 03:39 PM
fbodyalltheway's Avatar
Car: 1992 firebird. 1984 Trans Am
Engine: 3.1L. L76 coming soon
Transmission: 700R4. T56 coming someday
I just used a chanel locks and bent it back to straight.
C409
Sep 1, 2015 03:42 PM
MY87LT
Aug 17, 2015 08:43 AM
redbird_400
Dec 9, 2001 04:34 PM
fly89gta
Theoretical and Street Racing
Sep 21, 2001 11:50 PM
whiterocz
Jun 12, 2001 05:58 PM
