Painting Issue
Old Mar 10, 2012 | 11:28 AM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Painting Issue
I finally got around to spraying my '90 RS yesterday and I got the first thin coat down when the air compressor I rented failed.
I returned it and the only other alternate compressor is rented for the weekend. I have finals this coming week, so I won't be able to acquire another compressor during the week.
So, my question is, can I just get another compressor next weekend and continue spraying? Or will there be problems with the paint adhering since it will have fully dried? I sure don't want to have to sand the entire car again if I don't have to.
Thanks for any input.
Old Mar 10, 2012 | 01:19 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Re: Painting Issue
WASH...wax and grease...scuff...wax and grease...tack rag...respray and your good to go.
Old Mar 10, 2012 | 01:26 PM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
Re: Painting Issue
Grease? What?
Old Mar 10, 2012 | 03:07 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Re: Painting Issue
wax and grease remover, its a cleaning solution to prepare for paint
Old Mar 10, 2012 | 06:41 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Painting Issue
Yes you'll need to sand it again, but as mentioned, scuff it with a red scotch brite if you're using single stage and a gray one if you're BC/CC.
Old Mar 10, 2012 | 07:10 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Painting Issue
Alright, thanks for the guidance.
There was a run or two I spotted, I'll take care of that with the scuff pad.
Old Mar 10, 2012 | 09:33 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Re: Painting Issue
If there are you will need to sand it smooth again, scuffing wont do the trick with certains aka runs
Old Mar 10, 2012 | 10:32 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Painting Issue
Alright, so I'll probably have to use 400 grit sandpaper or something on the runs then? The scuff pad will suffice for the rest of the car though, correct?
Also, what grit sandpaper equivalent is a scuff pad?
Old Mar 11, 2012 | 08:43 AM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Re: Painting Issue
You could use the 400 for a quick minute but i would use 600
Old Mar 11, 2012 | 11:34 AM
Engine: N/A 350
Transmission: TH350
Re: Painting Issue
I love these threads, I don't know shizz about body work.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
deracer
Apr 11, 2016 12:04 AM
neekolzun
Aug 24, 2015 04:59 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
