D A Problem
Old Mar 10, 2012 | 09:16 PM
85Irocket's Avatar
Car: 85 Iroc
Engine: Don't have one yet.
Transmission: T-5 non wc
Axle/Gears: Disc brake 10 bolt with 373 gears
D A Problem
I'm having problems with my 80 grit psa discs flying off of my 6" DA sander. Anyone have this problem? Thanks
Old Mar 11, 2012 | 07:18 AM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Re: D A Problem
are they the self adheasive kind or do you have a spray can? the self adheasive kinds don't have very much "stick" to them.....the surface of your DA needs to be pretty clean and dry before you stick them on there...give it another try!
Old Mar 11, 2012 | 10:10 AM
85Irocket's Avatar
Car: 85 Iroc
Re: D A Problem
They are the self adheasive kind. I'll try to clean the sander and try again. Those things really fly when they come off. lol
Old Mar 11, 2012 | 01:08 PM
hotrodln's Avatar
Engine: Lt1 in IROC
Re: D A Problem
another trick i use sometimes is to try and start sanding on a flat surface with a brand new disc...it really helps it to get "stuck".....when removing them, they always come off better when they are hot....as in you just finished doing a panel....when they cool off they are quite stuck!
Old Mar 11, 2012 | 04:51 PM
85Irocket's Avatar
Car: 85 Iroc
Re: D A Problem
It was a brand new pad. I cleaned it with some Mineral Spirits. Works great now. Thanks.
Old Mar 11, 2012 | 06:30 PM
hotrodln's Avatar
Engine: Lt1 in IROC
Re: D A Problem
sounds good! post some picts when your done!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
