removing the doors?
Old Apr 7, 2012 | 07:20 PM
bigtizzles's Avatar
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
removing the doors?
Hi, When I get back to the States, I wanna paint my door jams with the door off, so I can paint around the edge of the door as well, hinges etc... I am going to remove the door so I can do a good job. I'm worried about aligning the door when I"m done, so it doesn't scrape the **** out of my newly painted jams when I close it the first time. Should I unbolt the door hinges from the car, or try to smack out the hinge pins and separate the hinge in half?
Old Apr 7, 2012 | 07:43 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: removing the doors?
In order to seperate the top hinge the "pins" have to be ground out. I think its easier to do with the door removed. Plan on replacing the wear parts while you are at it. I spent $260 for strikers, pins, dentent roller, bushings, all were due for replacing.
Old Apr 8, 2012 | 04:38 PM
bigtizzles's Avatar
Engine: 327 sbc
Transmission: TH350
I'm more concerned with getting the doors aligned when I put them back on, and not scratching the newly painted jams. Any advice for puting them back on? Or is there not that much adjustment in them, and they pretty much only go on one way?
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
