Rear deck lid w/ Wiper
Old Apr 15, 2012 | 05:14 PM
855speed's Avatar
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
Started refinishing my Iroc for paint, and I may have run across a rear decklid w. rear wiper for cheap. My car has RPO code C25, which means it originally had the wiper until someone replaced the deck lid. Can someone post pictures or the switchs used to activate the wiper, and maybe a a picture of the rear lid with wiper already on a car. Also, where does the wiring run to the wiper motor?
Attached Thumbnails Rear deck lid w/ Wiper-040712130856.jpg
Old Apr 15, 2012 | 05:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear deck lid w/ Wiper
Do a search on my name and "rear wiper" and you should find info/pics.
JamesC
Old Apr 15, 2012 | 05:34 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I wonder if they changed out the plastic inside the car which allows the wiper motor room. Have you checked that too? You might need the plastic from the seller. I like that option, it seems pretty few and far between. I would change mine if I could find all the right parts to a rear wiper car.
Old Apr 15, 2012 | 06:22 PM
JamesC's Avatar
Switch. Rear pump. Nozzle.
JamesC
Attached Thumbnails Rear deck lid w/ Wiper-img_0481.jpg   Rear deck lid w/ Wiper-img_0480.jpg   Rear deck lid w/ Wiper-img_0482.jpg
Old Apr 15, 2012 | 06:23 PM
JamesC's Avatar
Deck. Motor housing. Wiring.
JamesC
Attached Thumbnails Rear deck lid w/ Wiper-img_0485.jpg   Rear deck lid w/ Wiper-img_0484.jpg   Rear deck lid w/ Wiper-img_0483.jpg
Old Apr 16, 2012 | 04:43 AM
855speed's Avatar
Engine: 5.0L HO L69
thank you JamesC, just what i needed. I have the washer pump under the hood (disconnected), the nozzle on the roof, have to look at the switch this morning(can't remember). I do not have the contact Pad on the interior trim panel, or any extra wiring back there. Next stop, look at my wiring diagrams and look in the dash for the clipped wires.
Old Apr 16, 2012 | 06:07 AM
JamesC's Avatar
I'd remove the interior trim piece and take a look. I suspect the wiring harness was simply disconnected. Why the original trim piece was replaced is anyone's guess. Should be an easy replacement.
JamesC
Old Apr 16, 2012 | 08:18 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I'll bet they switched the whole hatch, not just the deck lid. Hopefully they left the harness in place behind the rear trunk panel.
Old Apr 16, 2012 | 04:14 PM
855speed's Avatar
Engine: 5.0L HO L69
Didn't see the harness there, but I will pull the LH sail panel etc and maybe it is tucked in there. Will look in a hour or so, going to look at a local hatch that is really cheap and need to grab my Saab. (Don't like driving the truck)
Old Apr 17, 2012 | 11:59 PM
tlandoe's Avatar
Car: 1983 camaro z28, 1981 honda cb650
Engine: Lu5 305 crossfire v8
Axle/Gears: 2.93
huh, that's not where my wiper switch is at, mine's underneath the headlamp switch
Old Apr 18, 2012 | 05:41 AM
JamesC's Avatar
The IROC's foglight switch is in that location.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
1992Z28!
Nov 19, 2015 07:33 AM
scottmoyer
Sep 7, 2015 07:06 PM
