Driver's side mirror
Old Apr 17, 2012 | 04:55 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
The other day my wife was driving my car and when she shut the door, the little peg came out of the adjustment hole, and the mirror is just kind of flopping around. I looked in the hole and all I see is bits and pieces.
What do I need to do to fix this? Is it expensive? Anyone have any extra's laying around?
I am getting really tired of this car. It seems to be starting to nickel and dime me to death!
Old Apr 18, 2012 | 07:07 AM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Re: Driver's side mirror
Bump
Old Apr 18, 2012 | 07:42 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Iv got a mirror here, it's manual
Old Apr 18, 2012 | 10:54 AM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
how much shipped to 27107?
Old Apr 18, 2012 | 01:48 PM
Engine: L31 350
Let me look
Old May 3, 2012 | 12:40 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Power mirror guts and manual mirror guts are not the same. As a matter of fact - Power mirrors have at least 2 different types of guts, 2 different glass frames, a few different motors as well as 2 different types of plugs. All power mirrors should have the 'Peg" your looking for,...... manual mirrors use cables.
Check out this pic:
It shows the attching clip in the center and adjustment pegs. Notice that there are a couple versions, 1 has peg on outside and bottom but the other has a peg on the outside and a peg on the top.
If the peg itself is busted,..... All you'd meed to do to repair this is to pull the mirror frame off the motor, clean the old peg from the hole, push replacement peg back in place, and re-install the mirror frame. Obviously; you will need to be carefull not to bend the frame and crack the mirror ! ( If you do break the glass a new Dorman replacement glass is about $12 )
If the plastic peg mounts on the back of the frame are broken than you will need to simply pull the original frame off and install a replacement. Just be sure that you get the right frame !
Hope that helps !
Old May 3, 2012 | 05:17 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Mine was not a power mirror. I had a little peg that was used to adjust the mirror, but it used cables to actually do the moving.
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
86IROC112
Aug 20, 2015 12:18 PM
Cameeeero
Aug 20, 2015 03:06 AM
89FormulaMan
Aug 10, 2015 10:01 PM
blacksunshine'91
Aug 10, 2015 12:04 AM
