Water Leak 92 firebird :(
Old Apr 29, 2012 | 08:31 PM
Kerch5's Avatar
Car: 1991 camaro rs, and 1992 bird 3.1
Engine: 305 tbi
Axle/Gears: granny gears
Hello, new member so wasn't sure where to post this? But... every time it rains out i noticed i would have a puddle of water collected on the passenger side floor pan (1992 firebird 3.1). I started by spraying the door with a hose, nothing, windsheld, nothing, then i sprayed it into the vent between the windsheild and hood.... i could c a steady line of water leaking in (i pulled the carpet back). My heat works, my dad thinks its the heater core, but it leaks when i havent even drove the car... anyone no the problem? thanks guys
Old Apr 29, 2012 | 09:04 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Water Leak 92 firebird :(
Sounds like you body chalking is all dried out.Check and see if your drains are not clogged on the passenger side and see if your chalking is cracked.
Old May 2, 2012 | 04:55 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Mine does the same thing sometimes. Do you happen to have any pics?
Old May 2, 2012 | 07:10 PM
Chachi361's Avatar
Car: 1992 Camaro rs
Engine: Stock 305
Transmission: 5 speed
i can almost guarentee you that the leak is comming from the firewall under the blower motor. my 92 camaro had the leak and my dads old one also did. the best way to check is to remove the kick panel screws ( i wanna say there is three screws). and peel the carpet and foam stuff back u should be able to see the firewall, inspect it to see if you can see any rust holes in the fire wall. i fixed mine using fiberglass to cover the hole.
evilstuie
Apr 14, 2016 08:52 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
