Gas tank leakage
Old May 12, 2012 | 04:02 PM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
Gas tank leakage
So I bought the car last year and I have noticed that the neck of the gas tank as I am making a hard right turn will let the gas run out of the car through the cap and you can see the running marks down the side of the car. Does anyone have any idea on how to stop this from happening?
Old May 12, 2012 | 04:55 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Gas tank leakage
Get a new cap?
Old May 12, 2012 | 05:48 PM
N_da_Mood's Avatar
It came with a brand new cap and I also bought a new one thinking it may just be the cap
Old May 12, 2012 | 06:21 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Is the restrictor still in the filler neck? Did someone drill a vent hole in the cap? Just some ideas. They do or did make a vented cap for these cars. Not sure if yours should be unvented or vented. 92 I'd guess unvented.
Old May 12, 2012 | 08:01 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Could also be the joint at the filler neck leaking. I had this problem and mine would leak if I filled the tank.
Old May 12, 2012 | 08:11 PM
N_da_Mood's Avatar
I also have that problem, how did you fix it? or did you just put a new tank in?
It could be that the restrictor is missing but how would I go about fixing that?
Old May 12, 2012 | 08:26 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Yea I just put in a new tank. The old tank was probably repairable, but I just didn't want to deal with that. I also put in a new sending unit and pump too since its a real pain to get to that stuff and I don't want to do that job again.
Old May 12, 2012 | 09:05 PM
N_da_Mood's Avatar
I actually replaced the fuel pump and sending unit once and fixed the leak in the joint, but after I changed the pump it came to my realization that the car still wasn't running so I took it to a mechanic and they said the parts store gave me the wrong fuel pump. Long story short he replaced it and now the neck joint is leaking again.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
