change to tilt steering in 86 camaro
Old 10-15-2000, 08:40 PM
bradkeith's Avatar
What is involed in changing to a tilt steering column. i have a 86 camaro, and am thinking of buying a tilt column out of a 89 iroc camaro. Would it just bolt in?
Old 10-15-2000, 11:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
to answer the swap part,,,yes
the other part,,,I can't tell you detials,,,I've yet to go pull the one I'm wanting to be able to tell you how much of a PITA it is
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Virtual Racing
- intelligence is learned, ignorance is universal
Old 10-16-2000, 09:46 AM
mike88RS's Avatar
it is actually real straight forward. I did this swap the first week I owned my 88, after putting my knees into my then perfect dash and splitting down the edge
there are three bolts on the iteriorside of the firewall, hit those first. there is also a bolt under the hood, connected to the universal joint part of the steering shaft. finally, pull down the column cover(shoud be 2 or 4 7mm bolts) and pull the four 10mm mounting bolts, disconect all wiring, AT shift lock and youre set. the other column fits in exactly the opposite way. only problem i see you facing is 89 is VATS column. Im not sure if that wil have any effect on your 86(wiring to switches in different positions) one last word of advice; tilt columns and standard columns use different ignition switches, just in case you need to change, your old one is NOT compatible.
good luck, and enjoy your "new" column.
mike
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
Mutillator
Exterior Parts for Sale
01-02-2016 06:44 PM
Zachattack0925
08-12-2015 09:52 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: change to tilt steering in 86 camaro
