Installing new pin and bushings in door hinge
Old Oct 15, 2000 | 02:33 AM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
How do I get the darned door spring out of the way? How have other people on this board handled this task before? I tried but couldn't get it to budge even slightly. Any help appreciated.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
Old Oct 15, 2000 | 11:54 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Those are a big PITA!
I've seen a tool designed for that. The body shop next door has one.
Its just a real skinny spring compressor.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 16, 2000 | 07:43 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Is the spring fastened to the door in any way or just wedged in there? I wouldn't mind doing away with that stupid friggin' thing just so that the door would open and close properly?
Old Oct 16, 2000 | 08:41 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
They are just wedged in there. You can get it out with a pry bar...just look out, they come out in a hurry
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 16, 2000 | 09:59 PM
Lostsol's Avatar
My friend and I had to replace the top hinge in my car, and the pin & bushings in the lower hinge, we ended up using a pair of duckbilled vise-grips that we ground one side down just thin enough to fit in between the spring as wide as we could to clamp down and take it out, it still needed some help with a screwdriver though, but didn't have near as much spring while it was clamped in the vise grips. Maybe that'll give you an idea, take care now.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
bryan623
Aug 10, 2015 11:33 AM
