firebird and camaro shift plate differences
From: First one out of liberty city, burn it to the ground
the t5 im getting to replace my 700r4 has a camaro shift plate with it...and i wanted to see if it was possible to make it work with a firebird?? i dont really wanna spend the $
88 Firebird 2.8
MODS (either coming or on):
Flowmaster Cat Back, Random Technologies Cat, 3" intermediate pipe, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6a, B&M Shifter, Transgo Shift Kit, Cold Air Induction, NEXT MOD: 5 speed...(torque convertor going so 5 speed a better idea) ..Then peeling and cracking paint..
88 Firebird 2.8
anyone?
88 Firebird 2.8
88 Firebird 2.8
Car: 88 GTA
Engine: 350, 383
Transmission: T-56 & 700R4
Don't bother with the Camaro plate.
You can enlarge the Firebird opening by cutting away the shift indicator window frame (med gray) with a fine tooth sabre saw/blade.
Cushion the bottom of the saw, or conversely the trim panel with masking tape to prevent the foot of the saw from marring the surface. Remember to cut close to the edge, but not on the edge. The rest can be taken down with sanding/filing.
This is what I did for my T-56 install. Results were very clean. Use a an aftermarket shift boot. I used a Mr. Gasket "Euro" boot.
I am thinking that this opening should be sufficient for your T-5 install as well.
Ryan MacEwen Pruyn
MacEwen Motorsports
1987 GTA 350 6spd, White OEM instruments, 17" Borbet Type A's, 275/40ZR17's, 255/45ZR17's, Koni Sport Adjustables, Eichbach Sport Springs, Poly U, everywhere, Guldstrand Engineering Panhard rod, LCA's
Ryan MacEwen Pruyn
MacEwen Motorsports
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
dhonda200
Aug 11, 2015 11:50 PM
