Is there a fix for a sagging headliner?
Old Nov 7, 2000 | 06:57 PM
Jester's Avatar
Topic says it all...Is there any other option aside from replacment?
Old Nov 8, 2000 | 12:54 AM
86ZRICHIE's Avatar
It shouldn't be too hard to do. I imagine all you would have to do is remove the headliner, get some interior adhesive spray from an autoparts store, spray it on the headliner itself and restretch the fabric tightly and make it smooth. You could go a step further and replace the fabric with some from a fabric store. My friend found some that was an exact match and even had the foam backing. Hope this helps, Good luck!
Old Nov 8, 2000 | 07:48 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can't reuse the sagging fabric. The ashesive will soak right through it and look really bad. If the car isn't a t-top car, recovering the headliner is a no-brainer and can be done for virtually no cash. Jo-Ann Fabrics sells the headliner material for $10 a yard, and a can of 3M spray adhesive is like $7. Just brush the old foamy gunk off the headliner, spray the backside of the fabric and the headliner, wait 5 minutes, then start laying it down inch by inch. If you have t-tops, I would suggest you use something like tweed or another fabric that has some flex/give to it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 8, 2000 | 11:55 AM
FormulaGod's Avatar
If you want a good job, get adhesive. If its a mickey mouse job, staple it
"Ever notice how imports sound like weedwackers"
Old Nov 8, 2000 | 07:09 PM
Jester's Avatar
Awesome...I wouldn't have thought it was that easy. thanks.
92firebirdguy
Sep 1, 2016 07:53 AM
PurelyPMD
May 5, 2016 04:57 PM
InfinityShade
Sep 18, 2015 08:32 PM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
