3rd gen stripes
Old Jun 7, 2012 | 11:33 AM
grampaben's Avatar
Car: 1987 IROC-Z
Engine: 383 stroker, 1st F.I. TPI
Transmission: 700R-4. Modified to handle engine
Axle/Gears: 10 bolt 3.42 posi
3rd gen stripes
I've seen a lot of 3rd gens on the board with the striping removed.
Is there an easy way to do it? I can't afford a repaint, but I sure would like to get those stripes of the car.
Any info would help
Gramps
Old Jun 7, 2012 | 05:18 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 3rd gen stripes
If your talking about decal striping,just use a heat gun or hair dryer.
Old Jun 8, 2012 | 07:34 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: 3rd gen stripes
Yes, use a heat gun to soften it.If your lucky most of it will peel off, then you can use turps or similar to remove the adhesive residue.Turps shouldn't hurt your paint but test it
on a hidden spot first.Don't have the heat gun too close.
Alicat.
Old Sep 21, 2012 | 09:11 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
Re: 3rd gen stripes
I am in the process of prepping for a respray. I found a "magic wheel" (3M wax wheel for your drill) that took off the striping today pretty quickly without a heat gun and didn't damage the paint. Only thing to be cautious of: the factory red under the stripes looked, well factory. Next to the old shitty paint you could see a clear difference. Depending on how good or bad the rest of your paint job is, you might want to keep the stripes.
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
