Diffrent Front End or is it GFX
Old Nov 24, 2000 | 06:14 PM
85IROCTPI's Avatar
I know some camaro's have a different nose but i saw two irocs side by side and the noses were dfferent and both stock. Was their a change possibly around 89 or so ?
3rdgen.fbody.com - Leading the F-body into a 5th generation
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
"Their's nuthing like the sound of a small block chevy and a bass thumping sound system in the morning" - me
Old Nov 24, 2000 | 11:03 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
All stock IROCs had the same nose. GM used 3 different noses throughout the years with ground effects packages. The 82-84 style nose, the 85-90 style nose, and the 91-92 style nose.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 25, 2000 | 12:59 PM
Blade's Avatar
Well actually it was more then 3. In 83-84 they had the nose with the 3 tall slits in the middle. In 85 the sport coupe got the nose with longer and thinner slits.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Old Nov 25, 2000 | 01:59 PM
85IROCTPI's Avatar
see msg below
[This message has been edited by 85IROCTPI (edited November 25, 2000).]
Old Nov 25, 2000 | 02:01 PM
85IROCTPI's Avatar
Then how is it the 85 IROC (yellow) looks like the nose is not as tall as the 88 IROC (red)
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
Old Nov 25, 2000 | 09:43 PM
jason86/2.8's Avatar
Looks like a custom grill of something to me on the one on the right. I like it though!
1986 SC in Berlinetta clothes, 2.8L, newly rebuilt 700R4, 3.42 Posi. 132K miles and counting, K&N air filters.
Old Nov 25, 2000 | 09:52 PM
Monkie's Avatar
looks the same to me. And the red one if it is lower is maybe because the springs are worn out.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Kills:
95 (****) Probe GT
94 4.6L Mustang
91 CRX (dont ask me why he raced me)
2nd Gen Z28 (350) haha to you V8 guys!
More to come
Old Nov 25, 2000 | 09:58 PM
86ZRICHIE's Avatar
I think it's just a trick your eye's playing on you. Between the 88 being slanted, having a different paint (metallic paint being the key) and different stripes it just has the appearance of looking different, but most likely if both had primed noses, they'd look exactly the same.
Old Nov 26, 2000 | 01:38 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Measure the grille.Red one looks like it's taller than the other.
Old Nov 26, 2000 | 12:42 PM
85IROCTPI's Avatar
Rspeed - my point exactly !!!
Old Nov 26, 2000 | 04:36 PM
Jim85IROC's Avatar
Re-read my original post. There where 3 different styles with the ground effects. The cars without ground effects also had unique noses that changed throughout the years, but that wasn't the focus of my post.
The IROC Homepage
Old Nov 27, 2000 | 12:11 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
well, either the yellow IROCs nose is aftermarket or just different or my car has the same aftermarket nose as the red one. The bottom of the grill opening is below the bottom stripe on my car just like the red 88. The yellow 85s grill opening is definitly not as large as the 88s. Somebody with a 85 go check their grill. See if they changed.
Old Nov 27, 2000 | 02:48 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Shadowing is the trick on the eye.
Stare close enough and the red opening will shrink when you see some of the 'black' of the opening is really the red of the car,,only very dark because of the light(probably angle too,, like one car looks wider than the other)
From 85-90 the valance panel (gfx piece) was the same for Z-28 & IROC-Z and the nose cover itself was the same from 85-92 only using different valance panels(85-90/91-92) and grille inserts to make them look different.
New website home
**The ****** at Anzwers.org deleted all of my files w/o notice**
- 4 out of 5 people think the 5th is an idiot
[This message has been edited by deadbird (edited November 27, 2000).]
Old Nov 27, 2000 | 06:28 AM
85IROCTPI's Avatar
Then how do you guys explain this one too ??
IROCZDAVE's white 88 and Omar's black 89
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
Old Nov 27, 2000 | 04:20 PM
deadbird's Avatar
Engine: TPI 305/ v6
The white does not show shadows making the black grille look smaller against the white color.
Old Nov 27, 2000 | 05:54 PM
Jim85IROC's Avatar
The black IROC on the right has a 91-92 style grill. That grill is the EXACT same size as the grill on my 85. They are all the same.
The IROC Homepage
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
