door interchange
Old Dec 2, 2000 | 09:01 PM
camaro_dude's Avatar
door interchange
I am wondering if a set of 83 firebird doors will fit on a 83 camaro? I need to replace my doors, and i have a friend who has had an 83 firebird in there garage for 3 years and wants to just give me the doors if they work.
Im new with owning a camaro so i really have no idea.
Old Dec 3, 2000 | 03:18 AM
AmorgetRS's Avatar
They should. Only difference would be ground effects, but if neither have them... well, you are set!
Old Dec 3, 2000 | 05:28 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Lol I am positive they will. I have an 83 firebird and my passenger door is from a camaro. All 82-92 F-body doors will interchange, but there are minor changes in the inner workings. But 2 83 doors will be the same.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Dec 3, 2000 | 09:54 AM
Thanks alot for the info....i'll be picking up those doors a.s.a.p.
The big bonus is...they are free!!!! he even told me i could take anything from it as long as when im done i call the junk man for it.
Old Dec 3, 2000 | 12:04 PM
327 firebird's Avatar
Ok I've never done this before but by see a firebird and camaro side by side the way the roof slants on the firebird seems to me a little different than the camaro. So the window might have a little different shape. Just something you might want to check before installing it. I'm sure you will be able to switch windows between the firebire and camaro doors and I know the doors themselves are the same just the windows look different to me and maybe the triangle seals. Someone please varify this for me? Just somethin to look at before its installed and it might be different
Old Dec 3, 2000 | 05:56 PM
Excellent point.....when i get them i will make sure i check that out, and if need be i will switch windows. Thank you for pointing that out 327 firebird.
Old Dec 4, 2000 | 09:20 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Nope, the windows are identical. GM does this to save money - this way they only have to design one window for both cars. Like I said, I have a Camaro door, not even an 83, on my passenger side. everything works fine.
LG4-Based Chevy 400
700R4 Tansmission
3.23 Posi Rear
100WX2 Amp
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
86IROC112
Oct 9, 2015 10:38 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
sbrandon
Sep 9, 2015 07:31 AM
