DOOR HINGES
Old Dec 4, 2000 | 05:17 PM
84,86,88Z28's Avatar
DOOR HINGES
HI,
I WAS WONDERING IF SOME ONE COULD HELP ME OUT. MY UPPER DOOR HINGE HAS A GREAT DEAL OF PLAY IN IT AND THE DOOR SAGS SEVERLY. I WAS WONDERING HOW TO REPLACE THE BUSHING, OR IS IT MORE MAJOR THAN THAT? IT IS A 86 Z28 IF THAT HELPS. THANKS
Old Dec 4, 2000 | 09:18 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
dude,everyone here hates CAPS,I'll forgive you based on your junior member status.welcome to the best thirdgen site on the web,you'll learn alot here. yes the hinges are a pain in the a$$ from what I hear. I haven't braved mine yet. I got the replacement copper bushings from the local GM dealer they had them in stock for $3.65 ,classic ind. sells whole hinges for big $$$
Old Dec 4, 2000 | 09:28 PM
84Trans-Am's Avatar
I just had the same problem. I tried every cheap way I could think of and just made a mess. after talking to a GM dealer three or four times I found out that there was no kit for those little bushings and pressed looking studs. I ended up buying the whole preassembled hinge. It came w/ instructions how to take off the old welded hinge with drills and a chisle. I used a grinder w/ a cutting blade. To put the new hinge on you have to be careful to get the new one in the right spot, but there is some room for adjustment. You drill four holes and there is an anchor plate on the back that is threaded. if its not in the right spot you can elongate the holes and retighten the 4 bolts. Mine seems alot better but its a stripped door no weatherstrip or interior
hope this helps
just try to have patience
Old Dec 5, 2000 | 02:38 PM
thanks guys i guess i will just try to buy the new hinge. thanks again.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Veaceonee
Sep 29, 2016 08:15 PM
86IROC112
Oct 9, 2015 10:38 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
