will wrap around work in place of the aero spoiler?
Old Jun 21, 2012 | 07:27 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
just wondered cause im tired of people wanting an arm and a leg for the aero spoiler that goes on my my car. jy sed i could have the wrap around for 20.00 what im asking is will it bolt up or get whole hatch?
Old Jun 21, 2012 | 12:43 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: will wrap around work in place of the aero spoiler?
You will likely have to drill holes for the wraparound spoiler since they probably mount in a different place, but otherwise it should work.
Old Jun 21, 2012 | 12:52 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Yep. Hafta fill the old mounting holes & drill new ones. The Areowing also has clips on the side of the glass that holds it down, but not sure how needed those really are. When I switched to a 4th gen wing I had to take those clips off & it has been fine for like 5 or 6 years now & stayed down without those clips.
Old Jun 22, 2012 | 11:24 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i have the replacement areo wing and im VERY pleased with it even though it cost what it did. after you have it and its on the car you will be glad you did spend that much for it.
a friend that grew up around the body biz is VERY critical and was plesantly suprised at how well it fit and its overall appearance.
save the hassle and get the correct wing for your ride.
Old Oct 28, 2012 | 10:34 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Sorry to raise this thread from the dead, but where did you purchase the aero wihg? Anyone else have input? Thx!
Old Oct 28, 2012 | 02:12 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i bought mine direct from HAWKS with a friend which helped shipping cost and the boxing cost.
i measured the ocation of the clip mounts on the glass and tranferred that to the recesses under the wing, poked the 3 holes, put good screws on the holes and slid the wing on. i avoided using the clips that screw in at the tip of the spears as they looked uglyand i couldnt see how they would hold as well as the way i mounted mine.
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
AkDrifted
Aug 17, 2015 07:45 PM
Randomtask2
Aug 13, 2015 01:57 AM
