Tail light housing
Old Jun 26, 2012 | 10:48 PM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
Tail light housing
i have done some searching about separating the tail light housing, but i have a a few probably stupid questions but if i can save myself from buying a new tail light from ebay. although hawks does have a new set i would really like but cant spend 350 dollars on
i have a set of taillight housings from my old 84 trans am with all the mounting pillars ( im not to sure what you call them but you screw the nut to them) and when i got a new to me 86 trans am it had the grid style which i like better, but i only have the passenger side. their is a driver side at a local junk yard for 25 dollars but has a few broken mounting pillars on it. so my question is can i swap the lenses so i can have all the mounting pillars?
Old Jun 26, 2012 | 11:00 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Tail light housing
If the 2 lights are what I think your referring to? Then no. The bulbs behind the lenses are arranged totally different as well as different wiring. You could adapt the older wiring to the newer lights though.
Old Jun 26, 2012 | 11:03 PM
Car: 1986 Trans Am
Axle/Gears: IDK yet
so even if i adapted the wiring the lenses are still not swap able? im not to afraid of the electrical because i would like to LED lights while im working on the tail lights
Old Jun 26, 2012 | 11:08 PM
Car: GTA
Got a pic of the 2 style lights to share? Pretty sure which ones you are referring to but.....
Old Jun 26, 2012 | 11:36 PM
Car: 1986 Trans Am
Axle/Gears: IDK yet
these are the ones i have that have a good mounting points, i dont have an actual picture of mine, but this is the style
Old Jun 26, 2012 | 11:55 PM
Car: GTA
Those are what I thought they were & the bulb arrangements inside are different. You can swap the entire lights & rewire the wiring, but not just the lens to the other housing.
Old Jun 27, 2012 | 07:57 AM
Car: 1986 Trans Am
Axle/Gears: IDK yet
well nuts lol. thank you for the help, saved me a bit of time.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
