ok, confused as hell
I was told that I will need a "headlight core" for my 1985 IROC. Ok, no problem. Called the salvage yard, they ask which side. I am confused; had thought the headlight core was one piece. Asked around here, found out that yes, it is indeed 1 piece. Ok, no problem. Went to the yard today, and I only found two pieces on the Camaros that looked like what I thought a headlight core looked like. Like, a piece per side. Now, was I looking at something different or what? Can someone explicitly describe or post a pic of what a "headlight core" looks like? Thanks a bunch
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
There is no such thing as a "headlight core" that I know of. I am a firebird guy, but that still doesn't sound right. Who told you this, and did they try to sell you one? You are going to have to ask them to be more specific and show you the piece that is worn. It sounds to me like your being scammed. Be careful.
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
There is a fiberglass or plastic piece that holds all of the headlights in place, that might be what they are calling a headlight core. It's kinda odd shaped and has the four headlights plus four studds that help hold on the nose cone. Make sure that's what they are talking about and don't get scammed.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Maybe this will help you out some True,,,
#2 is the 'mount panel bracket'
I realize we could describe this all day long,, but a pic is worth a 1000 words huh ?
Hope this helps better
Da Boid
- 4 out of 5 people think the 5th is an idiot
[This message has been edited by deadbird (edited December 22, 2000).]
Da Boid
That's perfect. I do believe that is the part I need. Mount panel bracket, eh? Well, alright, mount panel bracket it is. -=) Thanks to everyone who helped out with this. Deadbird, where did you find that diagram?
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
www.parts.com is where the pic came from.
neat little trick - right click on any pic or graphic online, and you can select "properties" and it will give you the url for the pic.. so you know the location.
this works with IE.. I know Netscape does it simmilarly, but it's been awhile since I used it.
Proud owner of the slowest L98 in the North East
1987 IROC 5.7 - 16.43 @ 82 the project
1986 S10 4x4 w/93 Vortec 4.3 - the nitemare
1988 Formula WS6 - the Cow
Car: 1990 Formula
Engine: 5.7 liter
yeah, it is pretty simple huh.....
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
I have experience...unfortunatly,its a result of bad judgement.
bubbaz28
Sep 18, 2015 02:09 PM
