Removing console
Old Dec 28, 2000 | 11:00 PM
83camaroZ28's Avatar
Removing console
I have a 1983 camaro Z28 and I was wondering how to remove the console so i can do some work on it. I'm not sure exactly where the bolts are that hold it to the floor or how many there are. Any help would be nice. Pictures would be great. Thanks
Old Dec 29, 2000 | 08:48 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I have tons of pictures of my interior project, but none go into detail as to what you have to remove to do it. So I'll try to explain the best I can.
Remove the shifter ****. You didn't mention if it was automatic or not, so I'll go with how I did mine (88). There is a staple in the front side of the ****. Carefully, with a pair of pliers and a little screwdriver, pry it out and pull it out. The **** comes off. Next, you'll probably have to remove the hand brake handle. Pull it up, and take out the screw on the driver's side of the handle. It should slide off.
Next, you have to remove the shift indicator/ash tray plate. Remove all screws w/ hex screwdriver and take it off. There is a light attached to it. Just turn counterclockwise to unlock and it should come out. Next, there are two screws inside the "glove" box or center console bin. Remove those. I "think" there are a couple of screws above the climate control area you have to remove too. One in each corner. Then the top portion of the console should come off. Becareful, this plastic can be fragile and you have to maneuver it to get it off. Also, when you get it high enough, remove the power windows, rear hatch release buttons (if equipped). You may be able to remove these switches after removing the shift indicator/ashtray plate.
If you want to remove the lower part, the key things are to remove the two bolts towards the rear, the one in the middle bolting the two metal pieces together and then two screws, one on each side, mounting to the underside of the dash. Remove the radio/climate control and that should come out.
i may be forgetting something, but at least this should help get you going.
Allan
The Camaro Shrine
'88 Camaro IROC-Z 350 TPI
'98 Grand Prix GTP 3.8L SC
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Nov 13, 2011 | 07:10 PM
Pught61's Avatar
Car: 1992 Camaro
Engine: 305 tbi
Re: Removing console
Allan i am wanting to remove the center console for some custom work i am considering leaving it out you said you have some pictures, i would love to see them.
Old Nov 13, 2011 | 07:47 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
theres 2 screws that hold it to the floor in the storage area. then theres screws that hold it to the dash under the radio trim plate. theyre under the ac controls IIRC. you have to remove the under dash pad on the driver side or the console will get hung up on it. its held on with 3 torx screws.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Fronzizzle
Sep 8, 2015 12:10 PM
