Mold / Musky smell - - how can I kill it ??
I found out that while the car was parked for the past 6 months waiting for the machine shop to do their work on the new LT1 the RS was getting a rear seat full of water. The leak was coming in from the rear hatch which I have not replaced yet. Water was apparently pooling under the rear seats. There is no rust, thankfully! But I went in and tore out the seats and cut out the carpet from the front seats back. Getting rid of the carpet has kept the car dry - the sound material was acting like a giant sponge. So it's ok now and before it started snowing I was airing the car out as much as possible.
BUT - I know the car will still have a tinge to it. I plan to replace the whole carpet but don't want to have to replace the seats since they're all in excellent shape.
So what can I do to get rid of the mold? One friend suggested Febreze. I don't want a temporary fix or something that I have to apply regularly. Is there anything I can do that'll get it on the first pass? Maybe a car bomb - like the dealers use? Anything like that? Any help would be appreciated. Want to get it running and ready for the new season.
1991 RS LT1 - red/black, all-forged 355 with Stage 2 GTP heads and custom grind, bolt-ons, and maybe a D-1sc on the horizon.
2000 C5 Coupe - black/black 6-spd, optional polished rims, 13.05 @ 109.52 showroom stock.
http://bs.cz28.com
http://bs.cz28.com
I had the same problem as you. Go to pep boys and buy something called "The Odor Gun". It's $3.99 and kicks a$$! I tried everything to remove the smell out of my car.
Baking soda, Febreze, a whole can of Lysol (no kidding)!
The odor gun worked though. Shoot like 5 sprays in there and you're done.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported & polished plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My car got so damp it literally grew mold on the seats and dash board. Joy. Anyway, I febreeze'd the hell out of it, then did some 70mph driving with the t-tops off and the windows down. Problem solved
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Elephantismo
Feb 13, 2019 12:51 AM
1Aauto
Sponsored Vendors
24
Mar 27, 2018 11:59 AM
Glowsock
Sep 11, 2015 11:09 PM
