trim on top of door
Old Jan 4, 2001 | 04:57 PM
zee28's Avatar
Car: 86 iroc
trim on top of door
how do i get it off without breaking it,and what will i need(clips etc)to replace when i put it back on?just to make sure everything is tight.Replacing door seals and there is a screw under this trim.
~mike~
1 superclean 86IROC-Z
Old Jan 5, 2001 | 04:36 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
From the inside of the door, grab the panel firmly with both hands, squeeze it with your palms up and out - it's very easy to break the little clips so take care with it.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 5, 2001 | 08:43 AM
zee28's Avatar
Car: 86 iroc
thanks,so this trim panel(top)can be removed without taking anything else off?my book shows door panel and everything else coming off first.thanks for your time.
~mike~
Old Jan 5, 2001 | 12:27 PM
KS91Z28's Avatar
Are you talking about the part that you might rest your arm on if the window was down? If so, the you will have to take the whole door panel off. They come off together.
Old Jan 5, 2001 | 12:42 PM
Vortex_89rs's Avatar
In my 89, you did not have to take the door panel off to take that top plastic piece off. Just be VERY VERY VERY careful that you don't break the clips that hold it on. It might be easier to take the door panel off first, but if I remember correctly, I think the piece overlaps the door panel. Oh, and don't get mad at it, cause that only promises you more broken clips (hahaha).
Vman
1969 Camaro
383, Corvette heads, 700R4
Resto is in progress
1988 Toyota 4-Runner
aka the Parts Hauler
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Old Jan 5, 2001 | 01:08 PM
zee28's Avatar
Car: 86 iroc
All the books i have on the camaro,they say the whole panel has to come off first?
~mike~
Old Jan 5, 2001 | 01:43 PM
Saywhut's Avatar
The hard plastic peice you are referring to is screwed outo the door panel itself, at least on every one I've seen.
To remove the door panel, first get the window down, then remove the armrest, any trim plates, switches, (power door lock & mirror if equipped),window crank handle if equipped,and the door handle trim plate.
Be careful on the trim plates, they have "dummy" torx screws that don't come out, if they don't turn easily try another one.
I think they only have 2 each that actually hold them in.
Then remove the trim plate under the door handle, (a little tricky but not too hard), then, using a gasket scraper, putty knife, or whatever, carefully pry the door panel off, the retainers are all the way around, (bottom & both sides) about 6" apart. You want to be gentle here to not tear the cardboard of the door panel.
Now all that is holding the panel is the 4 or 5 "tabs" under the window "fuzzy" at the top.
You should be able to push in & up on the black peice to remove the entire door panel as a unit.
Old Jan 5, 2001 | 02:03 PM
zee28's Avatar
Car: 86 iroc
thanks saywhut,I am replacing the panels with new ones so I dont have to be too careful.I assume the clips are reusable?
~mike~
Old Jan 5, 2001 | 05:18 PM
Saywhut's Avatar
The clips are part of the black peice on the top of the door panel, they hang down between the glass & the inner door.
If you look close, (window down), under the "fuzzy", you can probably see them. The plastic actually fits "over" the top of the inner door. The "clips" basicly keep it (door panel) from leaning in on you when you're sitting in the seat.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
