GT auto acces 4th gen wing fit on a regular non-aero spoiler hatch?
Old Dec 28, 2000 | 10:52 PM
theformula's Avatar
My 91 formula's original hatch was damaged and replaced with a 85 Trans Am hatch that doesnt have an aero spoiler.
So it doesnt have the female clips welded on to the trim of the hatch.
Would the fiberglass aero spoilers from GT Auto Accessories (4th gens style) fit on my current hatch?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
Old Dec 29, 2000 | 08:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have a 91 GTA Spoiler on my 86 T/A.
My hatch was replaced before by the previous owner with an 84 hatch. I just put some foam weather stripping underneath the parts that would mount to the clips. The 4 bolts in the rear hold the spoiler very tight. I just put the stripping on so that it wouldn't rattle against the window.
GT Auto said the spoilers come with all mounting hardware, not sure if they supply the clips, but when bolted on, the spoiler shouldn't go anywhere.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Dec 29, 2000 | 09:57 PM
bigbird88's Avatar
Just put one on my car looks great there is no need for clips they send clips with it that work great. The body shop said it was the best looking fiberglass part they seen in a long time.
Old Dec 30, 2000 | 06:10 PM
HAMMER's Avatar
It will work. They do send the clips to attach the foward edges.Also, you won't be disappointed, their work is top-notch!
First hand knowledge.....Hammer
Can't wait to see their version of the ram-air hood....Should be killer!
1987 GTA,Black&Sinister.
383 ci TPI,700R4, 12 bolt,3.73:1,SSM lift kit,
home-made cold air induction.12.20's,no juice......yet
Old Jan 1, 2001 | 03:47 PM
millertime's Avatar
just put one on my car easy!! looks better the the factory one. hope there hood is done soon. any other 4th gen style hoods out there??
Old Jan 1, 2001 | 06:55 PM
MrJ's Avatar
MrJ
Hey just out of curiosity, how much do these spoilers cost?
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Jan 1, 2001 | 08:47 PM
millertime's Avatar
Mine with shipping was $435. The shipping was quite a bit but I checked on my own and no one would (ups, us post office,fedexground) ship the size of the box. The truck freight wanted about the same to del it to my house. The car was ready for paint and I had it in 2 days. It was worth it.
Old Jan 9, 2001 | 09:24 PM
gt auto's Avatar
Hey thanks guys, Glad you all like your wing. our hood should be done soon trying to keep up with spoilers and make the hood at the same time.
Old Jan 9, 2001 | 10:05 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
GT Auto, just to clarify, will any of the 3 different style spoilers fit a car originally equipped with the 87-90 style aero spoiler? I'll be buying one of the 3 styles in the spring when I redo my 88 GTA, and I don't want to cut it up or drill extra holes just incase I decide to go back to stock in the future. As usual, my stock spoiler is shot and I'm trying to decide between the 3 styles. I guess I'll have a chance to see pictures on people's cars between now and then.
BTW, whatcha got in store for hoods? Maybe I'll need one of those too
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
[This message has been edited by Jim85IROC (edited January 09, 2001).]
Old Jan 10, 2001 | 09:04 PM
gt auto's Avatar
Hey you will have to drill new holes to fit the 91-92 and the new 4th gen style wing. the 85-90 style is a bolt on no drilling or cutting. I my self like the 4th gen style the most, but if you want to keep it factory it's up to you. I filled my holes and if I ever need to put the factory wing back on I could drill them back out. let me see if you go from the 4th gen style back to the 85-90 if it will cover the holes. I'll let you know
Old Jan 11, 2001 | 04:10 AM
SlowCamaro88SC's Avatar
gt auto......... are their any plans for camaro parts??? I think a redesigned 3 piece spoiler would look nice. like make it higher. Or something comparable to the '97 rs's that I see all the time. Have a small rising spoiler (like a '88 sport coupes, or a shorter height-wise '91-'92 z/28 spoiler w/ a 3 piece wraparound on top of it. or '93-97 camaro-z/28 hoods might look neat.
Old Jan 11, 2001 | 04:21 AM
theformula's Avatar
I agree with SlowCamaro, a slightly altered version of the Z28 spoiler used in 91/92 would look good.
91 Formula
305 TPI 5speed
1LE/G92/WS6
K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(47psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires,Bosch O2sensor, SLP headers & catback,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Jan 11, 2001 | 08:49 PM
gt auto's Avatar
We are looking into some wings for the camaros if you have any pictures of the two cars email them to gtautoacc@yahoo.com thanks
Frozer!!!
Jan 19, 2024 04:55 PM
lee01
Apr 9, 2016 01:56 PM
AkDrifted
Aug 17, 2015 07:45 PM
Randomtask2
Aug 13, 2015 01:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
