EMERGENCY....Please help!
Old Jan 19, 2001 | 05:55 PM
F22Raptor's Avatar
Hey guys, for the last few months I've been noticing a small pool of water on the floor, passenger side (where the floor is sunken)every time it rained. Today I lifted the carpeting and insulation to find out the source and was horrified to see lots of water under the carpeting. It seemed to me that water was getting in the car through the seams or in other words where the floor pieces overlay each other. Has this happened to anyone else?
I just ordered two spray cans of "Corroless" from "The Eastwood Company"; my plan is to clean up the seams with a wire brush and weld them all the way as much as I possibly can. Then clean it again and spray the "Corroless" stuff. Eastwood says this stuff is pretty good.
Am I on the right track to fixing my problem??
By the way, I'm taking eveything out of the car (seats, carpet, console, etc) so I can inspect and weld ALL this seams
Thanks for any help you can provide. I really appreciate your time!
Rick
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, intake pieces and 2100 RPM TQ
13.40@102.55 MPH
1.90 Sec ------- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Old Jan 19, 2001 | 07:06 PM
86IROCMIKE's Avatar
You will be allright
86 iroc,canary yellow,fully loaded
Old Jan 19, 2001 | 09:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's kind of rare....
You have T-tops, right?
The usual source of that problem is that water gets behind the rubber seal somewhere along the top, runs down the track the seal sits in, and drips into the car at the joint between the top and the top seal. Then it sometimes goes into the A-pillar trim and drips down the door panel to the floor, other times it just drips straight onto the seat.
Next time it rains see if there's water on teh door panel. If so, you know where it's coming from.
ICON Motorsports
Old Jan 19, 2001 | 10:37 PM
Red Demon's Avatar
That's what happened with my car.. exactly what RB said
Hey feel free to chat with me on AOL IM if you wanna.. Darkhal2000!
My site, http://www.personal.psu.edu/users/j/m/jmj211/index.htm
Old Jan 20, 2001 | 01:20 AM
F22Raptor's Avatar
the thing is I don't have T-tops!
Could it be coming from the firewall, right behind the engine? It's kinda hard to tell because water "travels" trough the insulation like bownty paper and water.....the paper sucks the water and you can see the water moving through the paper, so pretty much there is moisture almost on the whole passenger side; but the big pool of water is where the passenger puts his feet (in the big whole or dip)
Old Jan 20, 2001 | 01:24 AM
F22Raptor's Avatar
oh, I was thinking that maybe the whole chassis is bending and twisting since i run really strong and I had removed the front bumper (not the cover, but the metal inside) and haven't put my subframe connectors yet. I think this has weakened my car. Maybe this is the cause of my leaks
Old Jan 20, 2001 | 09:28 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I had the same prob on mine and don't have t-tops... Its the drain tube on the bottom of the A/C evaporator case. Its probably plugged with leaves and other compost (Nasty smellin' A/C air is a givaway)
Rain gets through the cowl and fills it up to the point it spills onto the pass floor. Or it could be a leaky windshield or t-tops?!?
[This message has been edited by JoelOl75 (edited January 20, 2001).]
Old Jan 22, 2001 | 06:37 PM
MNformula350's Avatar
Check your windshield weather stripping.
I had the same problem on my formula and that was the problem...
OH and by hte way i haver had this car 3 years and my 83 T/A 6 years and i NEVER once ahd a leaky T-Top...you just need to treat the seals once a month
84 FIREBIRD-2.8 V6,5spd super economy model
no options except t-tops( not even locking),no tilt,no cruise,no delay wipers,no rear defroter,no a/c,no rear spoiler(i put one on)no pw,pdl,pm,pseat,no gauges(just a 85 mph speedo with no trip odometer and a big f***in' gas gauge)
90 FORMULA 350-
Edelbrock t.e.s,gutted cat,Borla cat-back,LT4 hot cam ,24# injectors,holley h.p. fuel pump,K&N Throttle Body mounted air filter,52mm throttle body,accel 8.8mm wires,plugs cap and rotor,ADS superchip,GTA tailights,T-tops,4th Gen 17's with 275/40ZR17 Comp T/A's,93 Z-28 seats
No E.T's yet.
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Jan 22, 2001 | 08:49 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Try Joel's recomendation and the windshield and also remove the kick plate and check where the computer harness goes through the cowl and the harness for the door. Turn on the hose, set it on the roof and hop in to see where it's coming from. Don't waste time fixing things until you know where the leak is coming from.I would just seam seal if it's a floor joint. The factory did a good job of welding them and frame connectors will take up any slack. I've worked on alot of F-bodies and the only time i've seen a the floor rip or crack is in a collision. A hard one. Being a hard top is even more unlikely it's the floor. Welding up the foor just for the heck of it would be a waste of time. Spend the time instaling the connectors. Good luck, Kenney.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
72 Vista Cruiser 455
90 Olds Trofeo
80 K-10 w/snow plow
Painter @ Chevy dealer
GM junkie
