T-Top Glass edge moulding
Old Aug 6, 2012 | 10:39 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Hi. The top hard moulding on the edge of the T-Top glass is broken on both sides of the car. Can these be replaced? What are they called?
Thanks.
Old Aug 7, 2012 | 12:41 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: T-Top Glass edge moulding
Anything is possible,but I would invest in another set of tops.Checkout the exterior parts for sale and see who is selling a set or breaking up a car for parts.Their not that expensive.
Old Aug 8, 2012 | 02:07 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Found mine on eBay, around $60 w/shipping IIRC...here's one I found on the first page of 300 results for "92 camaro t-top". Note that there are two different materials that they make them out of: rubber, and hard plastic. Not sure which is correct for which years/models.
http://www.ebay.com/itm/82-92-Camaro...ht_1702wt_1398
Old Aug 8, 2012 | 02:59 PM
mantaguy's Avatar
Engine: 5.0 EFI
I don't think he's looking for drip edge,I could be wrong.Post a pic of the part your talking about!!!
Old Aug 8, 2012 | 03:38 PM
LHernandezJr's Avatar
Old Aug 9, 2012 | 12:18 PM
navy02ws6's Avatar
Pretty sure the larger, metal strip cannot be removed/serviced...the drip edges are notorious for rotting out and breaking off in chunks though (like mine).
Old Aug 9, 2012 | 07:39 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Originally Posted by motobooks
Do you mean the metal molding itself or the rubber weatherstipping? Not sure you can "break" the metal piece, but since you wrote "top hard moulding on the edge of the T-Top glass," I am not sure which one you're referring to.
Some of the rubber pieces can get really hard and brittle (that was the case with my window sweeps), so I am guessing you're talking about the piece at the very edge.
As suggested, posting pics helps tremendously.
Its the wide moulding on the top edge. I don't think it is metal because on the passenger side there is a chunk broken off the end. If it cannot be fixed, where would be a good place to look for new t tops?
Old Aug 9, 2012 | 08:24 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
It 100% for sure is NOT metal. Mine too is broken on the passenger side. I bought another set of tops. The pins or tops do not line up.... So what I did is took the whole t-top apart. This strip is plastic and seems to be held in by the sealant/automotive caulk. I have a heat gun but have not tried to remove it yet. Another top would be better but they are some variation in t-top (the GM ones)
Old Aug 9, 2012 | 09:14 PM
Old Apr 19, 2017 | 03:16 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
F-body-fan
Jan 12, 2023 01:49 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
gord327
Oct 3, 2015 01:25 PM
