Removing dash in a 92 RS
Old Jan 30, 2001 | 09:15 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I read the post for a 91, is it the same for a 92? If its different, how do I do it to change bulbs? Thanks.
Old Jan 30, 2001 | 10:18 PM
JPrevost's Avatar
Car: 91 Red Sled
Same thing. Just pop off front trim panel (2 screws on the bottom. You get to them by removing the heavy knee panel. Then there are 4 screws holding the actual gauge cluster in. Don't worry if they fall behind. Then remove the cluster slowely so as to not break off the little trip reset. The lights go in pretty easy just make sure you have the right bulb housings. The stock lights are tacked into the housings :-(
Good luck
, Jon (91 RS too many mods to list), getting new engine in summer
Old Jan 31, 2001 | 02:15 AM
Josh 91RS's Avatar
The bulb housings are for a 1/2" hole, bend the metal contacts down to make it fit tight otherwise it will feel like the housings are way too loose, and they also wont connect and work.
Old Jan 31, 2001 | 02:30 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
while you're in there, remove your speedo and spray some liquid graphite down the speedo cable..
oh wait, your car has the VSS right, not the cable? nm.
Webmaster: www.IROC-Z.org
Old Jan 31, 2001 | 10:13 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Just remember to tilt the steering wheel down to help remove the dash cluster. Also, the bulbs have a funky plastic bayonet fitting on them. They are identified as a 194 pc or 194 p, (I can't recall). At any rate, as usual GM wants a ridiculous amount for them. If you are careful you can get the plastic piece off the burnt out bulbs and swap in a standard 194 bulb which sells for like 1/10th what GM wants for them. I had to fiddle with it a little to get the bulb to make contact with the tangs in the plastic piece, but the price difference makes it worth our while. Good luck, Lon.
Old Jan 31, 2001 | 11:39 AM
Engine: 305TPI
hey Lon, you're correct
MetalliCamaroRS, don't get the ****ty, cheap bulbs.. get the 194LLBP.. they're in a red pack.. they last longer and are made in the US not TAIWAN.. trust me, I work at AutoZone
[This message has been edited by ColinOpseth (edited January 31, 2001).]
Old Jan 31, 2001 | 04:02 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Thanks everyone. How many bulbs are back there? Because I decided that while I have it all out I'm just gonna replace all of them.
Old Jan 31, 2001 | 05:24 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
90-92 Camaro, there are only 4 bulbs.
Old Feb 1, 2001 | 10:55 AM
Neo's Avatar
Neo
There are 4 bulbs for lighting up the console (speedo, tach oil, etc... But if you wasnt to replace your SES light , turning signals, bright indicator there is like another 5 more to do . I did this two weeks ago when I put on my guage overlays.
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
