Rear Hatch Pull Down Motor for 1988 Firebird.
Old Feb 5, 2001 | 09:36 AM
Kjohn21365's Avatar
Car: '88 Formula Firebird
I have replaced the motor to the hatch pull down. It worked one time - then nothing. I think I am missing part of the sensor that attaches to the hatch itself. Is there such a piece? There is an indentation in the hatch molding, but nothing there. It would match up with the metal plate to the left of the pull down motor. If there is a piece that needs to be there - what is it called and do you know the part number?
Old Feb 5, 2001 | 11:42 AM
'89Formula305TPI's Avatar
You don't mean the third brake light contact thing huh?
'89 Formula 305 TPI T-5
Check out my car HERE!
Old Feb 5, 2001 | 12:05 PM
Kjohn21365's Avatar
It could be the 3rd brake light - it has never worked. Would that effect the pull down mechanism?
Old Feb 5, 2001 | 01:46 PM
No, that has nothing to do with the pull-down mechanism, if you mean that metal sheet what is splitted four pieces.?
Old Feb 5, 2001 | 02:39 PM
Kjohn21365's Avatar
Yes, that is the thing I mean. Is that part or the 3rd brake light or is it part of the pull down?
Old Feb 5, 2001 | 03:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The pull down motor has nothing to do with those 4 metal tabs. There's a little plastic widget right next to the latch that operates the motor. In my GTA the motor would come up but then wouldn't go back down. It turned out to be internal to the motor, so I just swapped the whole assembly with my 86 SC.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 6, 2001 | 07:05 AM
Kjohn21365's Avatar
Thanks Guys, I figured out what was wrong - the hydraulic arms that hold the hatch up are too weak to let the hatch clear the switch in the pull down mechanism - so looks like I need new hydraulics. Thanks again.
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
stalkier
Aug 13, 2015 12:59 PM
Randomtask2
Aug 13, 2015 01:57 AM
z28addict8490
Aug 7, 2015 08:48 PM
