89 and 90 differences
Old Feb 1, 2001 | 12:12 PM
Sharpcorner's Avatar
What are the Int. and Ext. differences in an 89 and 90 Formula. I know that in 91 the Ext. changed, but what about the Int. Anyone have pictures of a 90 formula Int. I have an 89 now. But I'm going to buy a new formula soon.
1989 Firebird Formula L03
Stock except for K&N, Flowmasters, Centerforce Clutch, MSD 8.5, and Accel Cap and Rotor. Much more to come.
Old Feb 1, 2001 | 01:13 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I have a 90 Firebird. The only difference that I saw was the air bag, small difference in the dash meaning. There are switched (Rear defroster, Fog lamps and rear hatch release) above the A/C and the bottom part of the console has some sort of padding, I think they introduced the auto pull down on the read hatch, Rear shoulder seat belts.
Old Feb 1, 2001 | 04:59 PM
MNformula350's Avatar
90 was the first year for the airbag,rear shoulder belts,the dash is different-gauge cluster cover,cover under steering wheels,dash trim piece above radio/climate controls,hatch release and defroster switches....door panels,trim piece around door handle,first year for the cup holder/map pouches on the bottom front of the doors.
Exterior wise a 90 exactly the same as a 87-89.
Also the first year for the speed density(no mo mass air flow sensors) system on the TPI engines.
Also the power pull down hatch motor was first introduced on the 86 model f-bodies
84 FIREBIRD-2.8 V6,5spd super economy model
no options except t-tops( not even locking),no tilt,no cruise,no delay wipers,no rear defroter,no a/c,no rear spoiler(i put one on)no pw,pdl,pm,pseat,no gauges(just a 85 mph speedo with no trip odometer and a big f***in' gas gauge)
90 FORMULA 350-
Edelbrock t.e.s,gutted cat,Borla cat-back,LT4 hot cam ,24# injectors,holley h.p. fuel pump,K&N Throttle Body mounted air filter,52mm throttle body,accel 8.8mm wires,plugs cap and rotor,ADS superchip,GTA tailights,T-tops,4th Gen 17's with 275/40ZR17 Comp T/A's,93 Z-28 seats
No E.T's yet.
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
[This message has been edited by Dave84Bird (edited February 01, 2001).]
Old Feb 1, 2001 | 05:08 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Hey Dave thanks for the info on the rear hatch. Didn't the cup holder happen in 91 and 92 ???
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Feb 1, 2001 | 07:15 PM
Thanks guys, that gives me a place to start. I think that I will probably take either one. Anybody have some pictures of a 90?
Old Feb 1, 2001 | 11:25 PM
Greg90iroc's Avatar
my 89 RS had rear sholder belts. my 90 iroc has a diffrent dash and stering wheel with an air bag i assume that the changes were similar for the f-bird
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
Old Feb 2, 2001 | 04:33 AM
89FirebirdUK's Avatar
I have an 89 firebird, which has rear shoulder seat belts.
I have read somewhere that the interior was changed slightly in 90, but I'm not sure what was different.
Geoff
Geoff's Bird
Old Feb 2, 2001 | 04:09 PM
'89Formula305TPI's Avatar
my '89 formula has rear shoulder belts also.
'89 Formula 305 TPI T-5
Check out my car HERE!
Old Feb 4, 2001 | 03:34 PM
89FormulaL98's Avatar
i also have shoulder belts for my bird... my friend used to have a 90 formula, the only things i remember to be different were the steering wheel (it had an air bag) and the cup holders mounted on the doors. and a metal ash tray in the back as oposed to a plastic one.
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
Old Feb 5, 2001 | 02:04 PM
I have metal ashtray in the back also.
Old Feb 7, 2001 | 02:42 PM
Thanks guys, that is about what I thought. That atleast gives me a place to start.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
