Windshield gap
Old Feb 8, 2001 | 10:38 AM
Chris 611's Avatar
Windshield gap
I have recently gotten a '91 formula and noticed that around the windshield corners on the top, there are large (1/4") gaps between the sheetmetal and the rubber weather stripping that goes aroudn the windshield. I was wondereing if that weather stripping can be replaced without taking the window out. And where to find the weather stripping. Any help would be greatly appreciated. Thanks.
Old Feb 8, 2001 | 12:35 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It can be replaced, but the new weatherstripping is going to do pretty much the same thing.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 9, 2001 | 04:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't think that new weatherstripping will do that for a while, though. The front of that car might've always been in the sun. When I dropped my car off at the paint shop, Maaco told me $50 to replace the (damn I forget the name) windshield seal.. I told 'em to leave it alone. You can do it with the window out. The thing shoves into the gap.. it has grippers every few inches that look almost like a door panel clip's grippers do.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 9, 2001 | 05:23 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Chris, What happened is the windshield has been replaced before. Most if not all glass companies use a universal roll of weather strip. (sometimes called a reveal molding)It's not cut or relived at the corners so it usually shrinks in the corners. It can be replaced without taking out the glass but you should buy a GM piece. Any GM dealer can get one. Also, it will only fit 100% if the glass is taken out and placed back in. While the urethane is not set the windshield can be manipulated up to get a tight seal. Now that i think about it that may be what happened. The wind. was replaced and possibly slid down a bit before the urethane set. (not uncommon) Let a pro do it. A real pro. There seams to be alot of inexperience in the glass biz. If the the glass does come out make sure whoever uses two-part urethane. Remember inexperience leads to broken glass, scrached paint, cut headliners, gouged dash pads, and dents. Be careful. Good luck.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
72 Vista Cruiser 455
90 Olds Trofeo
80 K-10 w/snow plow
Painter @ Chevy dealer
GM junkie
Bohemian
Aug 15, 2017 05:11 PM
Veaceonee
Sep 29, 2016 08:15 PM
codeysabatini
Nov 10, 2015 04:07 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
