aluminum self made interior do you think it could work
Old Feb 16, 2001 | 10:31 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
hey guys,
im thinking about going to my local scrapyard and gettin some sheets of 1/8 thick aluminum. i was then going to cut them to fit over the dash pieces. basically making my own aluminum interior kit
what do you think
its an 83 with a black interior
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
MUSTANGS SUCK
Old Feb 16, 2001 | 10:39 AM
Blade's Avatar
I'd say it will look out of place in a thirdgen. Plus a PITA to do.. hehe
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Feb 16, 2001 | 10:47 AM
Axle/Gears: 3:08
yeah actually after i posted i thought about it some more and realized that it would be a PITA oh well it was just a thought
Old Feb 16, 2001 | 11:26 AM
FiReBReTHa's Avatar
im bored enufff,
got sum at school and was gonna try it already, ill post of how it goes
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Feb 16, 2001 | 11:53 AM
Axle/Gears: 3:08
im interested in seeing how it goes
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
MUSTANGS SUCK
Old Feb 16, 2001 | 11:38 PM
theformula's Avatar
The only way you'll do this successfully is if you have a machine to laser cut the aluminum to the exact specifications of the interior pieces you are replacing. Otherwise, you'll find yourself un-happy with the results.
www.wooddash.com has some cool kits for 3rd gen f-bodies. Interior pieces of any color carbon fiber you want, brushed aluminum, wood etc..
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires, custom fastchip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 19, 2001 | 01:59 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Why on earth would you need a lazer cutter? I have cut many pieces of aluminum, and I have never used a lazer cuter. I used a cut off wheel for the thicker pieces, and shears for the thinner ones.
And about how it would look, well, I think that it would look awesome!! I always wanted to do it, and now, I have to choose between alumium, fiberglass, or carbon fiber.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 19, 2001 | 09:01 AM
Axle/Gears: 3:08
i decided to go ahead and do it but im gonna powdercoat the aluminum with a transparent blue to math my car a little more. itll be thin enought that i dont think that i would need a lazer cutter.
i think itll be sweet
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
MUSTANGS SUCK
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
z28addict8490
Aug 7, 2015 08:48 PM
