Hatch Lock Repair
Old Aug 26, 2012 | 08:21 PM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Hatch Lock Repair
I did search but couldn't find anything quite like what I have. The bailing wire is factory right?
The icing on the cake:
There is a white plastic cylinder at the end of a cable that I think the lock cylinder is supposed to turn. How would this be retained on the lock?
Any suggestions on where to start with this mess?
Old Aug 26, 2012 | 10:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Hatch Lock Repair
You'll need a new latch assy, striker-sensing switch and guides. All three are available on my web site under the "hatch pull-down items" category.
http://www.top-downsolutions.com/hatch-pull-down-items
I forgot to mention you might want to read the Tech Article I wrote on repairing these pull-down units.
https://www.thirdgen.org/tech/hatchpulldown.pdf
Lon
Old Aug 26, 2012 | 10:29 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The safety wire comes dealer installed in the little cubby hole on the side panel.
Lonnies parts will help save you.
Old Aug 26, 2012 | 11:42 PM
Car: 1990 Camaro RS
Engine: L31
Well I got it tore down, very simple. I need new guides for sure and a housing as mine is busted off. It was also surrounded by bailing wire. I cannot figure out how the harness plugs into the motor. The harness has 4 fine connections where the motor has 2 wide connections. I'm going to assume I am missing something that goes between them but what is it?
Great write up on the tear down and rebuild Lon!
Old Aug 27, 2012 | 12:19 AM
lonsal's Avatar
Yep, you are also missing the reversing switch.
Lon
Old Aug 27, 2012 | 01:00 AM
Car: 1990 Camaro RS
Engine: L31
I ordered the nylon guides from you. I'm going to try my luck at the junkyard before I order the rest of the mess since I don't have a core for the reverse switch. I tested my motor with a motorcycle battery and it ran smooth so I think that part is still good.
Old Aug 27, 2012 | 10:00 AM
lonsal's Avatar
I agree with your strategy.
Lon
Old Aug 30, 2012 | 02:17 AM
Car: 1990 Camaro RS
Engine: L31
Found all the parts and it is now reassembled and working, thanks for the help and fast shipping Lon!
Old Aug 30, 2012 | 04:07 AM
byronagetz's Avatar
ITS Quit complicated i also tried it about 1month ago but i cant settle it down so i think you have to go for dealer so he will repair it by himself easily it will create problem again and again if you try to figure it out hope for the best
Old Aug 30, 2012 | 05:32 AM
lonsal's Avatar
Glad to help.
Lon
PurelyPMD
May 5, 2016 04:57 PM
whibbs
Exterior Parts for Sale
Sep 28, 2015 07:53 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
