Fender ?'s
Old Mar 2, 2001 | 07:52 PM
SpankuGta's Avatar
Fender ?'s
The passenger side fender is poped out from the previous owner and his walmart jack(Why are there so many cars like this dont people know not to jack there?),how can i get it to go back in place?
New owner of a 88 gta with 72k miles just started to modify it.
Old Mar 2, 2001 | 10:31 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
The best advice i can give is to do the opposite of what the jack did. It's hard to explain without seeing it, but here's a stab at it. If the pinch weld is damaged or collapsed fix it with channel locks, pliers, hammer, whatever it takes to get back to normal. Remove the tire and splash shield and persuuade it down with a 2x4 about 12-18 inches long and a heavier than normal hammer. Careful of your back swing. You want to "strech" the fender back to normal. If you cut the bottom of the 2x4 at a slight angle it will fit right in there and leave no external visible marks. Think about how you need to move it carefully before leaping. If you need fine tune it, remove the bottom bolt(s) and drill the hole(s) a little larger for more adjustment. Hope that helps.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
72 Vista Cruiser 455
90 Olds Trofeo
80 K-10 w/snow plow
Painter @ Chevy dealer
GM junkie
Old Mar 3, 2001 | 05:35 PM
SpankuGta's Avatar
Thanks for your help ill try it when it quits raining.
morrow
Jan 13, 2024 12:29 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
