T-Bar Rust Repair Help ASAP..
Old Mar 18, 2001 | 01:55 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I'm working on my T-bar right now.. and I'm trying to take this metal peice off.. but it doesn't want to move.. is there anything else other than the three screws.. Thanks
Here is a link to the pic if it doesn't work
http://www.unlimitedlights.com/t-bar.jpg
Ok, well I found more screws and the whole center panel is loose.. but what can I use to release the rubber seals that are attached to it.???
89 RS Camaro, LO3 305 TBI
L69 Duel Snorkel Intake
Dynomax Ultra Flo Cat Back
- Future Mods -
DynoMax Headers (Jet Hot)
[This message has been edited by FastElectrics (edited March 18, 2001).]
Old Mar 18, 2001 | 03:39 PM
Wolfcoast's Avatar
The whole T-bar is one piece. There should be 3 screws on each side for a total of 6.
oops. Just saw that you found the other screws hehehe.
As far as removing the weatherstripping on the T-bar. If you don't have new weatherstripping to put in.. DON'T REMOVE IT!!! Anything you do to try and remove it will ruin it. It is glued to the T-bar underneath the rubber.
Randy
84 Trans AM LG4, 700R4 T-tops
84 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
[This message has been edited by Wolfcoast (edited March 18, 2001).]
Old Mar 18, 2001 | 04:06 PM
Car: 89 Camaro RS
Engine: 305 TBI
Actually I found a total of 5 screws on each side, 10 in total.. There where two more under the seal. I was able to fold the seal back a bit to get at the screws. I heard somewhere of a release agent for softening the adheasive. But I can't find it. And new seals are NOT cheap. at least 400us . Soo I guess I'll have to try and fix the rust problem without removing the center moulding. That should be fun.. .. Thanks for your help anyways.
Old Mar 18, 2001 | 04:22 PM
Wolfcoast's Avatar
You should be able to get a complete weatherstripping kit for the T-tops from GM for about $140. That's what I paid about 3-4 months ago. Came with everything for the T-tops. Unfortunately I can't remember the part number though.
Randy
Old Mar 18, 2001 | 07:07 PM
Car: 89 Camaro RS
Engine: 305 TBI
Thanks Wolfcoast.. I'll check with the local dealer and see.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
