Rear quarter panel - THERES A HOLE!!!
Old Mar 18, 2001 | 08:39 AM
NewYorker's Avatar
Ok, I took off the ground effect from the rear quarter behind the wheel well and looked at it... my friend just touched it with one finger and BLAM! It just literally fell apart and now there is a hole big enough for you to fit your fist through.... and more then that is rotted also.
Where the ground effect bolts on is where the rust stops. What the heck can I do!?!?!?!?
Old Mar 18, 2001 | 09:06 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
You'll hear people tell you to fiberglass it, or Bondo it, but the only way to fix it is by cutting out the cancerous section and welding in a new section. Sorry
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Mar 18, 2001 | 12:26 PM
theformula's Avatar
More than likely those ground effects were replaced. Either by you, or by the previous owner (possibly an accident or something of that nature would deem necessary).
My guess is when the individual re-attached the ground effect, he failed to use any sort of silicone sealer around the hole and bolt. Which resulted in condensation, which resulted in rust.
You just have to replace it now like RCR stated.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March alt. pulley, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 18, 2001 | 05:22 PM
NewYorker's Avatar
I never had any accidents in the rear of the car... so that rules me out.
The holes where the ground effects bolt on are all fine.... I even took pictures which I am going to have to post at least two here....
Ok, this first one is when we first took off the ground effect peice....
And here is with a little primer on it so you can see it better:
Old Mar 18, 2001 | 06:26 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Ugh....time to junk it....j/k
The wonders of road salt, unfortunately, the only way to really fix it is to cut out the cancer, and replace it with new metal.
Pete
Pete's Place
HiOutput Tech Page
83 SC
205+k mile LG4/5-speed
14.935@94.14
Old Mar 19, 2001 | 03:05 AM
NewYorker's Avatar
BTTT
Old Mar 19, 2001 | 03:25 AM
theformula's Avatar
HOLY SHlT. That looks bad. You better take care of that soon.
Old Mar 19, 2001 | 07:23 AM
RCR's Avatar
RCR
OUCH!! That's a very typical spot to rust on any car. That and the doors. Look at Classic Industries. They might have the patch panel to fix that. I believe a place called Cars, Inc. here in Warren Mi makes replacement stampings. They did when I bought floor pans for an '80 Camaro at least. Good luck.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
